My domain is: www.exhibapi.dynu.net
im making a custom api framework for restfull http & websocket api’s, i’m making a function that will get a certificate for the server, but when ever i do this it fails even though i see that the acme server got the http-01 KeyData.
im making this in c# and im using Certes to call the api server to start the order
Accept Code: (c#)
if (ACMEChallenge != null)
if (Req.RequestPath == $"/.well-known/acme-challenge/{ACMEChallenge.Token}")
Req.Requester.Writer.Write($"HTTP/1.1 200 OK\r\nContent-Type: text/plain\r\n\r\n" + ACMEChallenge.KeyAuthz);
Console.WriteLine("Wrote:" + $"HTTP/1.1 200 OK\r\nContent-Type: text/plain\r\n\r\n{ACMEChallenge.KeyAuthz}");
Console.WriteLine();
ACME_Wait.Set();
return;
Request Function:
private Byte [ ] GetSSLCert(AcmeContext Context, String CertPassword, CsrInfo Info)
this.ACME_Wait = new ManualResetEvent(false);
IOrderContext Order = Context.NewOrder(new String [ ] { this.DNS }).GetAwaiter().GetResult();
IAuthorizationContext Auth = Order.Authorizations().GetAwaiter().GetResult().First();
this.ACMEChallenge = Auth.Http().GetAwaiter().GetResult();
Certes.Acme.Resource.Challenge Rest = this.ACMEChallenge.Validate().GetAwaiter().GetResult();
this.ACME_Wait.WaitOne();
Thread.Sleep(1000);
IKey KEY = KeyFactory.NewKey(KeyAlgorithm.ES512);
CertificateChain Cert = Order.Generate(Info, KEY).GetAwaiter().GetResult();
//ACMEChallenge = null;
return Cert.ToPfx(KEY).Build("BDHttpServerCertificate", CertPassword);
Console Log:
Note: it says “RECIVED NULL!” when ever the connection handler recives null from the stream reader, indicating the connection got shutdown or closed.
_az
March 21, 2019, 9:18pm
2
What was the result of the validation?
Can you link to the authz for one of your failed orders?
Hi @dedady157
is your website online? There are only timeouts.
it was offline, had to go to bed. ill set it up and leave it running today, but, acme got the data that was suposed to be on the site yet it failed
There you see the problem. The content:
HTTP/1.1 200 OK
Date: Fri, 22 Mar 2019 15:34:30 UTC+1
Server: BD Http & Https API Server
Content-Length: 87
Connection: Keep-Alive
aCp4zR1F7R64EOqKssZ3I0NYNPFfjgdtSeyZUg_BBuA.SmKxIwmqcAD__lHIcZcpyCS3hpg5ulcf6Zh_UVH-URQ
Your code sends the header lines as http content.
If you use something like
that's wrong. That's the content of the file.
There should be something like
Response.Headers.ContentType = "text/plain"
Writer.Write(ACMEChallenge.KeyAuthz)
ah so the content of the token should be within the header?
IE: “HTTP/1.1 200 OK\r\nContent-Type: text/plain\r\n{other headers…}\r\n{Token}”
this is the responce writer’s code:
internal void WriteResponce()
if (this.Sent)
throw new InvalidOperationException();
lock (this) // Lock Self
if (!this.Sent)
this.Sent = true;
this.FillHeaders();
this.Connection.Writer.Write($"HTTP/1.1 {(UInt16)this.Code} {this.Code.ToString().Replace('_', ' ')}\r\n");
foreach (String K in this.Headers.Keys)
this.Connection.Writer.Write($"{K}: {this.Headers [ K ]}\r\n");
this.Connection.Writer.Write("\r\n");
if (this.Responce != null)
this.Connection.Writer.Write(this.Responce);
this.Connection.Writer.Flush();
No. The file content is only the token.
Your code duplicates the Content-Type header in your document. Then another instance adds the date, Server and connection header.
Normally, you don't write a http/1.1 header with a 200 OK.
no, that was when i was writting it directly, now it’s writting it via the normal responce handler.
this is how the responce handler fills in the default headers:
private void FillHeaders()
DateTime Day = DateTime.Now;
this.Headers.Add("Date", $"{Day.DayOfWeek.ToString().Substring(0, 3)}, {Day.Day} {((MonthsOfYear)Day.Month).ToString().Substring(0, 3)} {Day.Year} {Day.ToLongTimeString()} {((TimeZoneInfo.Local.BaseUtcOffset.Hours != 0) ? "UTC+" + TimeZoneInfo.Local.BaseUtcOffset.Hours : "UTC")}");
this.Headers.Add("Server", "BD Http & Https API Server");
this.Headers.Add("Content-Length", (this.Responce == null) ? "0" : Encoding.UTF8.GetByteCount(this.Responce).ToString());
this.Headers.Add("Content-Type", this.ContentType);
if (!this.Headers.ContainsKey("Connection"))
this.Headers.Add("Connection", (this.Code == HttpResponceCodes.Switching_Protocols) ? "Upgrade" : "Keep-Alive");
for me its sending the data correctly, and there isnt any headers within the content/message body
im not seeing it
Ps: since i restarted the server it tryed to do the challenge agen.
challenge uri:http://www.exhibapi.dynu.net/.well-known/acme-challenge/M3i5BBl5Ypu7_2xTfUwGISXLrMw5dMq8xxr7UwiPMnI
I don’t see Html, instead I see the raw content:
HTTP/1.1 404 Not Found
Date: Fri, 22 Mar 2019 16:42:26 UTC+1
Content-Length: 160
Content-Type: text/html
<html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server.</p><br><p>Using Http</p></body></html>
yea thats a valid http/1.1 responce so, i dont get why its not working…
do you mean i have to build in an exception that just shoves out the responce, not incased within a http/1.1 responce body??
if so, how the heck is this supposed to work with a webserver on the usual basis???
dedady157:
this.Headers.Add("Date", $"{Day.DayOfWeek.ToString().Substring(0, 3)}, {Day.Day} {((MonthsOfYear)Day.Month).ToString().Substring(0, 3)} {Day.Year} {Day.ToLongTimeString()} {((TimeZoneInfo.Local.BaseUtcOffset.Hours != 0) ? "UTC+" + TimeZoneInfo.Local.BaseUtcOffset.Hours : "UTC")}"); this.Headers.Add("Server", "BD Http & Https API Server"); this.Headers.Add("Content-Length", (this.Responce == null) ? "0" : Encoding.UTF8.GetByteCount(this.Responce).ToString()); this.Headers.Add("Content-Type", this.ContentType);
And that's wrong.
The .NET HttpWebResponse object has some standard header properties. Use these instead of creating own header entries.
everything is directly written to the tcp steam, it never touches anything else. and i don’t want to have to figure out a way of working around something that wasn’t built for the porpose at hand. like i said in the main post, this is a custom api server, everything other then certes is self contained, from the connection handler to the request parser and responce writter.
what header is missing i can easily add it in
im guessing its the ‘Content-Encoding’ header?
this is just for getting responces from an outgoing http request, i cant use it here, since i need to be the one creating them
But you write it too late, the real headers already sent.
So it's content, not header-content.
noooooo, look i accept a tcp stream, if the stream sends me a valid http request type first 7bytes i hand it over to the http connection handler, witch will then go ahead and unpack the request, it will then send that request up to the main server container witch will then processs the request, if it is a predefined reqeust such as the acme-challange it will write the responce to the RAW tcp connection, there is NOTHING on top of it, other then the networkstream witch DOESN’T write to the tcp connection, it mearly acts as a data helper above the raw tcp socket. so there is in no way anything being sent to the tcp connection other then what im sending it, there is no duplication of the headers or anything like that since i have to send them, and nothing will ever automaticly handle it outside the http api server framework, witch is “me”
ill post the code for handling http connections, and show you the path witch the request takes
Http Handler:
private void WorkThread()
while (this.BaseSoc.Connected && !this.IsWebSocket)
Dictionary<String, String> Headers = new Dictionary<String, String>();
String NextLine;
String [ ] Segments;
String Path;
HTTPRequestTypes Type;
try
NextLine = this.Reader.ReadLine();
if (NextLine != null)
// Parse Request Head
Segments = NextLine.Split(' ');
Type = Enum.Parse<HTTPRequestTypes>(Segments [ 0 ]);
Path = Segments [ 1 ];
// Read Headers
while (NextLine != "")
Segments = NextLine.Split(':');
Headers.Add(Segments [ 0 ], Segments [ 1 ].TrimStart(' '));
// Get PostData if any
if (Type == HTTPRequestTypes.POST)
if (!Headers.ContainsKey("Content-Length"))
Console.WriteLine("POST WITH NO CONTENT-LENGTH");
HttpResponce Res = new HttpResponce(this)
Code = HttpResponceCodes.Bad_Request
Res.WriteResponce();
continue;
Char [ ] PostData = new Char [ Int64.Parse(Headers [ "Content-Length" ]) ];
this.Reader.ReadBlock(PostData);
this.Parent.Processes(new HttpRequest(Type, Path, Headers, new String(PostData), this));
else
this.Parent.Processes(new HttpRequest(Type, Path, Headers, this));
else
Console.WriteLine("RECIVED NULL!");
this.Dispose();
catch (IOException)
this.Dispose();
catch (Exception E)
Console.WriteLine("EXCEPTION WHILE ACCEPTING:" + E.ToString());
try
// BAD REQ
Code = HttpResponceCodes.Bad_Request,
Res.Headers.Add("ErrorCSType", E.GetType().FullName);
catch { this.Dispose(); }
if (this.IsWebSocket)// Saifty Switch
this.WebSocketHandle();
Reqeust Processer:
internal void Processes(HttpRequest Req)
OnHttpRequest?.Invoke(new HttpRequestInfo(Req));
HttpResponce Res = Req.GetResponce();
// Check if Request is WebSocket, if so, diff handling
if (Req.Headers.ContainsKey("Upgrade"))
if (Req.Headers [ "Upgrade" ] == "websocket")
lock (this.Routes)
foreach (HttpRouteInfo I in this.Routes)
if (I.Type == HTTPRequestTypes.WebSocket && I.Route.Validate(Req.RequestPath))
try
I.WsCallback.Invoke(new HttpWebSocketContext(Req, Res));
catch (Exception E)
Res.Code = HttpResponceCodes.Internal_Server_Error;
if (this.ReturnExceptionDetails)
Res.Responce = E.ToString();
else
Res.Responce = null;
return;
// 404 !
Res.Code = HttpResponceCodes.Not_Found;
Res.Responce = $"<html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server.</p><br><p>Using {(((Req.Secure) ? "Https" : "Http"))}</p></body></html>";
return;
if (this.ACMEChallenge != null)
if (Req.RequestPath == $"/.well-known/acme-challenge/{this.ACMEChallenge.Token}")
Res.Code = HttpResponceCodes.OK;
Res.ContentType = "text/plain";
Res.Responce = ACMEChallenge.KeyAuthz;
this.ACME_Wait.Set();
return;
lock (this.Routes)
if (I.Type == Req.RequestType && I.Route.Validate(Req.RequestPath))
try
I.Callback.Invoke(Req, Res);
catch (Exception E)
else
return;
// 404 !
Responce Writter (in one function):
if (this.Sent)
if (!this.Sent)
this.Sent = true;
if (Data != null)
