ok i’v looked into it, for some reason firefox doesn’t load the page at all. ill look into fixing that, maybe it will fix the other issue as well
and when i mean it doesnt load, it doesnt parse the responce as a http responce, it prints out the entire responce without parsing it
There’s a Unicode byte order mark before the data.
$ hd xqcLvoVuBoUMWLd9HWLNQuDR9Gs0y36i_LgVKfHu9tk | less
00000000 ef bb bf 48 54 54 50 2f 31 2e 31 20 34 30 34 20 |...HTTP/1.1 404 |
00000010 4e 6f 74 20 46 6f 75 6e 64 0d 0a 44 61 74 65 3a |Not Found..Date:|
00000020 20 46 72 69 2c 20 32 32 20 4d 61 72 20 32 30 31 | Fri, 22 Mar 201|
Plus it doesn’t close the connection after it finished sending the response.
Edit: Maybe ignore the last sentence. It does send a Content-Length
header, which the client ignores, because of the other issue.
so its sending a header in unicode? wtf
By the way, the time zone in the Date
header isn’t “GMT
Date: Fri, 22 Mar 2019 22:36:42 UTC+1
ok ill fix that in a bit, you sure that the UTF-8 header isnt just comming from wget writting to the file?
wget doesn’t add BOMs for no reason.
yea i’v set it up to where i serlize it and send it directly to the socket stream, the stupid ass StreamWriter thought it was writting to a file.
but the lets encrypt attempt still failed.
at least it load in firefox now
What error message did Let’s Encrypt have now?
1 sec, i got to remove some code to allow me to debug the error
ok i got a key type error, BUT IT FRIKING WORKS!
thank you so much man, i never NEVER would have thought it would add in an encoding header. and probably would of just given up. so thank you SO MUCH!!!
now i got a new issue. ;-;
’ policy forbids issuing for: “exhibitionhttptestingserver”’ ’
is this just something with the staging server?
The production and staging rules should be about the same, AFAIK. What name did you actually try to get a certificate for? It has to be something syntactically valid and not blacklisted (e.g. a large bank). www.exhibapi.dynu.net
would be good, localhost
or paypal.com
would not.
Certes.AcmeRequestException: ‘Fail to load resource from ‘https://acme-v02.api.letsencrypt.org/acme/finalize/53819622/366715481 ’.
urn:ietf:params:acme:error:malformed: Error finalizing order :: policy forbids issuing for: “exhibitionhttptestingserver”’
this is the Csr Info:
ok yea, i just relized my stupidity, the CN has to be the DNS name -_-
system
Closed
April 21, 2019, 10:01pm
36
