Problem: Key auth file did not match challenge
Dear community,
here the basic data of our problem:
solitaire-marketing.de
Certificate request in Plesk App “Let´s encrypt”.
Invalid response from https://acme-v01.api.letsencrypt.org/acme/authz/ZJ-zwYzdOE0BGYXxT3iCvIw4yrrarzeFDDHk-njrkds.
Details:
Type: urn:acme:error:unauthorized
Status: 403
Detail: The key authorization file from the server did not match this challenge [afpoJNZxCEnDao851hbCUhTRqlUZs1Ud50jxjzZJ7Eo.dy79C5ntjeiyKDOUk-clnTUStTXmWmCA7haFNVjDcpo] != []
Apache 2.4.18 / nginx 1.11.10
Ubuntu 16.04.4 LTS
none
Plesk 17.5.3
Description:
We have virtual hosting on this server and have already created Let´s encrypt Certificates for some other domains. But if we try to create a certificate for this domain (pure domain incl. “www”) this error appears. The key file is created in folder “/.well-known/acme…” and can be called from outside.
For the same domain we already created a certificate for subdomain “cloud” some months ago.
Because of this, now we made separate DNS A-records for “cloud” and “www”, because someone told us, this possibly could help. But it did not.
Do you have an idea what the solution may be?
Thanks for your help in advance!
Greetings,
Markus
That authz is for auslandsverkauf.de, not solitaire-marketing.de.
All requests to the former domain result in a 403, and don't seem to be hosted on a Plesk server at all.
$ curl -i http://auslandsverkauf.de
HTTP/1.1 403 Forbidden
Server: nginx
Date: Fri, 23 Mar 2018 21:45:29 GMT
Content-Type: text/html
Content-Length: 162
<html>
<head><title>403 Forbidden</title></head>
<body bgcolor="white">
<center><h1>403 Forbidden</h1></center>
<hr><center>nginx</center>
</body>
</html>
$ curl -i http://auslandsverkauf.de/.well-known/acme-challenge/afpoJNZxCEnDao851hbCUhTRqlUZs1Ud50jxjzZJ7Eo
Server: nginx
Date: Fri, 23 Mar 2018 21:49:19 GMT
Content-Length: 162
<html>
</body>
</html>
