Issue with Wildcard SSL?
My domain is: *.thetixcenter.com
I ran this command: (I am using the le-cpanel plugin)
There was a problem processing your request
Error issuing certificate
Failed to issue certificate
Error authorising domain (*.thetixcenter.com): acme error ‘malformed’: Error creating new authz :: Invalid character in DNS name
My web server is (include version): Apache 2.4.29
Centos 7
DigitalOcean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): cPanel (latest)
Based on these error messages, you are using the FleetSSL cPanel plugin (I'm one of the developers).
Let's Encrypt has not yet launched wildcard support, it will be going live at the end of February.
We have already updated the plugin to work with wildcards, and will be releasing support for wildcards with version 0.13.0, as soon as wildcards are available in production.
If you have further questions please email us :slight_smile:.
Oh dang, is there any way to get a temp wild card in the mean time?
As far as I know there are no certificate authorities that issue free wildcard certificates that you would be able to save and import into cPanel.
If you actually need a wildcard, then your options are to either purchase one, or use something like Cloudflare CDN which will terminate SSL for you with a wildcard.
If you just need a certificate for a number of subdomains as well as the main domain (up to 100 names), then you should be able to just use Let’s Encrypt.
