My domain is: habiboto.com
I ran this command: 1) sudo certbot --apache ] Another command here [ sudo certbot certonly --cert-name habiboto.com -d habiboto.com -d www.habiboto.com
:~# sudo certbot --apache
Enter email address (used for urgent renewal and security notices) (Enter 'c' to
cancel): XXXX@YYYYY.com
An unexpected error occurred:
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 159, in _new_conn
conn = connection.create_connection(
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 61, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.8/socket.py", line 918, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 665, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 376, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 996, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 314, in connect
conn = self._new_conn()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 171, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f81e1712a60>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 719, in urlopen
retries = retries.increment(
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Cau sed by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f81e1712a60>: Failed to establish a new connection: [Errno -3] T emporary failure in name resolution'))
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory ( Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f81e1712a60>: Failed to establish a new connection: [Errno -3 ] Temporary failure in name resolution'))
My web server is (include version): Apache/2.4.41 (Ubuntu)
The operating system my web server runs on is (include version): Unbuntu 20.04
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Putty
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
