Issue renewing SSL
My domain is: afuego.us
sudo lego --tls --email="support@afuego.us" --domains=“afuego.us” --path="/etc/lego" renew
You have to pass an account (email address) to the program using --email or -m
I was able to renew the SSL before without issues. Please advice, Thank you!
What version of lego are you using? It seems that in some versions, the --tls option expects an argument, and may interpret the next option --email as that argument instead of parsing it as an option itself.
I guess you might be following a tutorial for a different version of lego than the one you have installed?
The problem occurs when a user uses the CLI syntax of the lego v2 with the v1 binary.
lego v2:
sudo lego --tls --email="foo@bar.com" --domains="foobar.com" --domains="www.foobar.com" --path="/etc/lego" run
lego v1:
sudo lego --exclude="http-01" --email="foo@bar.com" --domains="foobar.com" --domains="www.foobar.com" --path="/etc/lego" run
