Is there any problem in my settings?
My domain is: koreanraichu.shop
I ran this command:sudo certbot certonly --webroot -w ./public -d koreanraichu.shop
http-01 challenge for koreanraichu.shop
Using the webroot path /home/ubuntu/public for all unmatched domains.
Failed authorization procedure. koreanraichu.shop (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: 13.124.69.40: Fetching http://koreanraichu.shop/.well-known/acme-challenge/9hYnlYkYh4swcOgq2HyTTTYkxpuE9gpcDSEGHYAyVL4: Connection refused
    Domain: koreanraichu.shop
    Type: connection
    Detail: 13.124.69.40: Fetching
    Connection refused
My web server is (include version): Not have. I upload python file and run it directly. (Flask project)
The operating system my web server runs on is (include version): Description: Ubuntu 18.04.6 LTS
My hosting provider, if applicable, is: AWS(EC2)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): no, I use terminal.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.27.0
I checked DNS and my domain, AWS instance(security) settings.
DNS type: A
Host: @
IP: (my AWS instance IP)
TTL: 600
and AWS instance:
also, ufw atatus is Inactivated.
Hi, your AWS network rules look OK. Does curl http://koreanraichu.shop work from the server itself?
  • If it does work there does seem to be a firewall blocking connections.
  • If not then there is nothing configured to listen on port 80.
Once you get http://koreanraichu.shop working your domain validation should also work.
I tried and saw
curl: (7) Failed to connect to koreanraichu.shop port 80: Connection refused
it means I have to configure to listen on port 80? how can I do this?
this is /etc/hosts in my AWS instance.
As you are using flask I assume this might mean configuring your listening ports in your app, however as far as I'm aware Flask is not a production web server itself and you should really run it behind a reverse proxy such as Caddy, nginx or apache Caddy has the benefit of automatically setting up https for you.
You can also just use the --standalone mode of certbot to cert your initial certificate (it does this by running a temporary http listener on port 80).
Oh, I using Flask.
Yesterday, I tried port opening use iptables and ufw on/off, but now I cannot access my site. It refuse all of connecton although port are opened in AWS Inbound.
when I learn about that, lecture did not teach about HTTPS and nginx, apache. It is too hard for me...
Yes, initially all of this stuff is quite complex. Luckily though it doesn't change that much over the years so once you know enough to get apps working etc there's not a whole lot more you need to do. I suggested Caddy because it's relatively new and getting it to work as a reverse proxy (an https front-end for your flask web server) is relatively straightforward: Reverse proxy quick-start — Caddy Documentation
Regarding your firewall, you probably switched it on when it was off before, you'll need to ssh into your server and turn that off (or configure which TCP ports to open). If you've accidentally blocked SSH at the OS level and now have no way to administer the server then you may be quicker recreating the VM (you can do things like attaching the disk to a different instance to recover data if required).
Thanks!
Altough I tried nginx, it occurs 'No such files or Directory' when I execute ini file, but I can install Certbot when I solute that problem.
@koreanraichu not sure what you mean by ini file? nginx has it's own .conf files and systemd has an ini-style formatted file to define services, is it one of those files? Or is the ini file related to Flask?
