Is there a way to check how many times request for domain was called
Hello Team,
I'm hitting this error:
"Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours
I'm wondering, if there is a way I can check how many times the cert was issued, prior to calling for issue of new one.
Is there an API that can give me this info?
Can you possibly share curl command or alternative to validate?
Regards
Hello @NLegal, welcome to the Let's Encrypt community. :slightly_smiling_face:
You can read about Rate Limits - Let's Encrypt
letsdebug-toolkit and https://crt.sh/ to check a domains issued certificates
Also please use the Staging Environment
And to assist with debugging there is a great place to start is Let's Debug
Thank you for assisting us in helping YOU!
And from here https://letsencrypt.org/docs/duplicate-certificate-limit/#monitoring-rate-limits
Monitoring Rate Limits
We do not offer a way to monitor subscriber rate limits at this time.
No, but I'm wondering why you're hitting that rate limit in the first place? That rate limit is there to prevent run-away ACME clients. You're not supposed to hit it.
