Too many certificates
api.mailshogun.com
cerbot
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: api.mailshogun.com:
nginx
ubuntu 18.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 0.31.0
------------------------ MY QUESTION -----------------------------------------------------------------------------------------
I dont remember i have done many retries. question is- how much time I have to wait? How I know how many retries were done?
Hi @nickpp
your configuration looks buggy.
Checking your domain and the CT-Log, you see ( https://check-your-website.server-daten.de/?q=api.mailshogun.com#ct-logs ):
Let's Encrypt Authority X3 2019-07-02 2019-09-30 api.mailshogun.com - 1 entries duplicate nr. 5 next Letsencrypt certificate: 2019-07-03 06:33:09
Let's Encrypt Authority X3 2019-07-02 2019-09-30 api.mailshogun.com - 1 entries duplicate nr. 4
Let's Encrypt Authority X3 2019-07-01 2019-09-29 api.mailshogun.com - 1 entries duplicate nr. 3
Let's Encrypt Authority X3 2019-06-30 2019-09-28 api.mailshogun.com - 1 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-06-26 2019-09-24 api.mailshogun.com - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-06-25 2019-09-23 api.mailshogun.com - 1 entries
Let's Encrypt Authority X3 2019-06-24 2019-09-22 api.mailshogun.com - 1 entries
Let's Encrypt Authority X3 2019-06-23 2019-09-21 api.mailshogun.com - 1 entries
Your Server creates 5 certificates, that hits the limit, then the next 5. That startet 2019-06-01, you have created 24 active certificates.
But you don't use one of these certificates, instead you use
CN=apidev.mailshogun.com
	02.07.2019
	30.09.2019
expires in 90 days	apidev.mailshogun.com - 1 entry
with the wrong name.
  1. Use
certbot certificates
to find the newest certificate.
  1. Use
nginx -T
to find your vHost, there change the certificate file, restart your nginx.
  1. Share your renew command. Perhaps you use the wrong --force-renewal in your config file or command.
The standard: Create one certificate, then use this 60 - 85 days, then create the next.
