My domain is: www.golfsub70.in
We are facing significant speed issues on our site and discovered that the SSL cert is from 'Let's Encrypt' but we have no record of this installation/configuration to properly trouble shoot. Please help!
For a speed issue, you will need to take it up with Shopify support or get help from the Shopify community. It would be unusual for a certificate to cause speed issues, outside of some exotic networking problems. But such a problem would generally be widespread affect and be noticed broadly, i.e. all Shopify websites.
Your hostname golfsub70.in (note: without the www subdomain) has two IP addresses configured:
23.227.38.65, which seems to be a Shopify address
192.64.119.233, which is a Namecheap IP address, responding to HTTP on port 80, but NOT to HTTPS on port 443, so you'd get a timeout after a while.
This last IP address is probably erroneously configured for your domain and leading to "speed issues", which ultimately probably is just the timeout for a non-responding IP address, and not a certificate problem.
