I use hpkp and with this my site wonât work. And why I have to whitelist any subdomains? I tried git. and cdn. and got the error that the domain isnât whitelisted
Second:
I tried the staging site to test the client and couldnât bring it to verify the challenges but my ip became not blocked. But on the live api my ip and the whole /29 inetnum are blocked.
The Account id is 80d0aabb72ed307595e8a00b3f93a266
Hi Knight,
I think you might have surpassed the rate limit. Possibly when using: DOMAIN1.deâ, â-dâ, âwww.DOMAIN1.deâ, â-dâ, âDOMAIN2â, â-dâ, âwww.DOMAIN2â
Here you are requesting 4 certs. At the moment only 2/week can be generated if I understand how things are now. It may take a week before you can try again?
I think that they mean 4 single certificates. And that's not my main problem because i switched to another host system so i circumvent the ratelimit atm. My Problem is that i can't re-issuance the certificate as per the information on the FAQ. But as i can see it is somehow possible to do this.
ACME is the used protocol and you can specify the server, even another one not being LE. So Iâd say itâs an ACME client, additionally, itâs also an LE client, because LE supports (only) ACME.
Ah okay. Thatâs true if the author wanted to say this in a more general way.
HoweverâŚ
(the nitpicker goes onâŚ)
⌠this bug report (âit did not used my own private keyâ) refers to the LE client, because other (currently not existent) ACME clients obviously do not have to have this bug.
And itâs also no bug in the protocol, but in the client implementation (of this specific client), so IMHO itâs clearly better to say âLE clientâ here.
Edit: Donât ask me why smileys like (:smile:) are now displayed in black/white styleâŚ
Test:
If you cannot see this here is the image it shows:
