My domain is: ccistraining.ca
sudo /opt/bitnami/bncert-tool
An error occurred creating certificates with Let’s Encrypt:
acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order
:: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too
many certificates already issued for exact set of domains:
ccistraining.ca,www.ccistraining.ca: see
https://letsencrypt.org/docs/rate-limits/, url:
AWS
Linux
AWS
Yes
or certbot-auto --version
if you’re using Certbot):
Hello, I had to install the Let’s encrypt yesterday to my domain around 5 times, as I had to restore the site almost every one hour to the right backup.
So at last when everything seems ok, I tried to create ssl again, and I got this error:
An error occurred creating certificates with Let's Encrypt:
I believe it happens because I tried to install it many time into different instance. how long do I need to wait to install the SSL?
Also is that possible to move the Let’s Encrypt form the instance that I have already installed the SSL. I sill have it running as I’m comparing the site between the old site and the one I restored from the backup.
Please help.
