Hi there,
Hope to get some help here on resolving this issue.
I’m using RHEL 7, Apache (hosted AWS).
Successfully enabled the EPEL repository and enable EPEL optional channel but got the following error after using the “sudo certbot --apache” command. Would be grateful for any help. Have copied the log below for your reference
[root@ip-[redacted] /]# sudo certbot --apache
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): [redacted]
tls-sni-01 challenge for [redacted]
We were unable to find a vhost with a ServerName or Address of [redacted].
Which virtual host would you like to choose?
(note: conf files with multiple vhosts are not yet supported)
1: ssl.conf | | HTTPS | Enabled
Press 1 [enter] to confirm the selection (press ‘c’ to cancel): 1
Job for httpd.service invalid.
Encountered exception during recovery
File “/usr/lib/python2.7/site-packages/certbot/error_handler.py”, line 100, in _call_registered
self.funcs-1
File “/usr/lib/python2.7/site-packages/certbot/auth_handler.py”, line 284, in _cleanup_challenges
self.auth.cleanup(achalls)
File “/usr/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 1945, in cleanup
self.restart()
File “/usr/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 1834, in restart
self._reload()
File “/usr/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 1845, in _reload
raise errors.MisconfigurationError(str(err))
MisconfigurationError: Error while running apachectl graceful.
What did i do wrong?
