Increate certificate issue rate limit?
begin certbot challenges
TASK [begin certbot challenges] ************************************************************************************************************************************************************************************************
fatal: [178.62.123.161]: FAILED! => changed=false
msg: 'Error new order: CODE: 429 RESULT: {''type'': ''urn:ietf:params:acme:error:rateLimited'', ''detail'': ''Error creating new order :: too many certificates already issued for exact set of domains: ekobox.co.uk,www.ekobox.co.uk: see https://letsencrypt.org/docs/rate-limits/'', ''status'': 429}'
other: {}
Server version: Apache/2.4.41 (Ubuntu)
Server built: 2020-08-12T19:46:17
Distributor ID: Ubuntu
Description: Ubuntu 20.04.1 LTS
Release: 20.04
Codename: focal
digital ocean
no
certbot 0.40.0
Really I just wanted to ask if there is any way the Cert issue rate limit could be lifted for one more call so I can issue a valid cert for this site. I have everything working and stupidly assumed that it was idempotent when running with a valid vert installed. I wanted to make the code a little better and deleted the cert files assuming it would just install a new cert as I had removed the keys.
Welcome to the Let's Encrypt Community, Richard :slightly_smiling_face:
Glad you got everything working.
:partying_face:
When testing, you want to use --dry-run to use the staging environment. Please add alt.ekobox.co.uk to your list of domains and try again. You can remove the alt before your next renewal.
Thanks so much Griffin, that sorted it. I have to say lets encrypt is such a fantastic tool!
We aim to please. :slightly_smiling_face:
By the way, you can always view your existing certificates at https://crt.sh if you want to know what you have generated. The certificates show in pairs: actual certificate then precertificate.
That’s super helpful, thanks!
