I'm not able to generate SSL Certificates
stg-cita.com
sudo certbot certonly --agree-tos --email amit@wiz.asia --webroot -w /var/lib/letsencrypt/ -d stg-cita.com -d www.stg-cita.com
http-01 challenge for stg-cita.com
http-01 challenge for www.stg-cita.com
Using the webroot path /var/lib/letsencrypt for all unmatched domains.
Challenge failed for domain www.stg-cita.com
Challenge failed for domain stg-cita.com
    Domain: www.stg-cita.com
    Type: dns
    Detail: DNS problem: NXDOMAIN looking up A for www.stg-cita.com -
    check that a DNS record exists for this domain; DNS problem:
    NXDOMAIN looking up AAAA for www.stg-cita.com - check that a DNS
    Domain: stg-cita.com
    Type: dns
    Detail: DNS problem: SERVFAIL looking up A for stg-cita.com - the
    domain's nameservers may be malfunctioning; DNS problem: SERVFAIL
    looking up AAAA for stg-cita.com - the domain's nameservers may be
    malfunctioning
NGINX
Ubuntu
Yes
No
certbot 0.40.0
Welcome to the community @AmitERP
As the message says, you must have DNS A and/or AAAA records for your domain name. These point to the IP address of your server.
But, do you own that domain? Because one domain reseller, GoDaddy, says it is still available for purchase. ICANN says the domain is not registered.
These say you don't own it which is the first step. You don't have to buy it from GoDaddy. But, you must buy it from somewhere
HI @MikeMcQ : Thanks for quick update. I made a mistake on domain name it was stg-cita.com not stg-sita.com but I still get the same error. I've updated the post. please check if you can help.
Hi @MikeMcQ : in ICANN Lookup it shows registered. the correct domain name is stg-cita.com
Your DNS server is malfunctioning for the apex domain: stg-cita.com | DNSViz
And it seems it's not aware of any www subdomain: www.stg-cita.com | DNSViz
