Hello, i have one NAS synology at my home.
How to create a ssl certificate.
Thanks
Thanks
Hi @Anju
Synology has integrated solutions you can and should use. There are a lot of users with Synology NAS and Letsencrypt certificates.
If you have a DSM, start there:
https://www.synology.com/en-us/knowledgebase/DSM/help/DSM/AdminCenter/connection_certificate
Hello,
I have try to add a crt and key but i have error “connection to Letsencrypt is impossible”.
Then please answer the following questions:
or certbot-auto --version
if you're using Certbot):
i not understand sorry
I would suggest asking on the Synology forum at
This is entirely dedicated to Synology support and there may be more people who can help you understand your problem.
I think the problem is going to be with your Internet connection in some way, though, because of the error that you got.
