Identrust.com CRL server not responding, connection error in Edge browser
Suddenly, my website (as well as this forum and any other Let’sEncrypt-protected site) isn’t working in the Edge browser.
Further investigation shows that the Edge browser is trying to check the CRL and is getting a connection timeout on identrust.com CRL and OCSP URLs:
http://crl.identrust.com/DSTROOTCAX3CRL.crl
http://isrg.trustid.ocsp.identrust.com/MFEwTzBNMEswSTAJBgUrDgMCGgUABBRv9GhNQxLSSGKBnMArPUcsHYovpgQUxKexpHsscfrb4UuQdf%2FEFWCFiRACEAoBQUIAAAFThXNqC4Xspwg%3D
etc.
>wget http://crl.identrust.com/DSTROOTCAX3CRL.crl
--2016-10-25 19:49:03--  http://crl.identrust.com/DSTROOTCAX3CRL.crl
Resolving crl.identrust.com (crl.identrust.com)... 192.35.177.64
Connecting to crl.identrust.com (crl.identrust.com)|192.35.177.64|:80... failed: Connection timed out.
Anyone have the same issue?
www.identrust.com is working fine.
No issues with those links here. Could you run traceroute crl.identrust.com? This would show where exactly the connection is failing. Odds are, this is a temporary network glitch somewhere between your ISP and IdenTrust’s ISP.
This is going on since yesterday (more than a day already).
c:\>tracert crl.identrust.com
Tracing route to apps.digsigtrust.com [192.35.177.64]
over a maximum of 30 hops:
  1     3 ms     1 ms     2 ms  192.168.1.1
  2     *        *        *     Request timed out.
  3    13 ms    12 ms    13 ms  vnn-rc0001-cr101-xe-1-0-2-0.core.as9143.net [213.51.188.17]
  4     *        *        *     Request timed out.
  5    16 ms    20 ms    15 ms  fr-par02b-rd1-xe-3-1-3-0.aorta.net [84.116.134.54]
  6    17 ms    15 ms    30 ms  xe-0-1-0.cir1.amsterdam2-nh.nl.xo.net [80.249.209.200]
  7   168 ms   167 ms   167 ms  te0-3-4-0.rar3.washington-dc.us.xo.net [207.88.13.198]
  8   164 ms   197 ms   172 ms  207.88.12.99.ptr.us.xo.net [207.88.12.99]
  9   160 ms   165 ms   158 ms  207.88.12.132.ptr.us.xo.net [207.88.12.132]
 10   166 ms   172 ms   167 ms  207.88.12.215.ptr.us.xo.net [207.88.12.215]
 11   167 ms   192 ms   165 ms  207.88.12.212.ptr.us.xo.net [207.88.12.212]
 12   163 ms   185 ms   175 ms  207.88.12.165.ptr.us.xo.net [207.88.12.165]
 13   166 ms   164 ms   167 ms  207.88.12.188.ptr.us.xo.net [207.88.12.188]
 14   164 ms   185 ms   203 ms  207.88.12.191.ptr.us.xo.net [207.88.12.191]
 15   168 ms   202 ms   203 ms  216.156.16.25.ptr.us.xo.net [216.156.16.25]
 16   165 ms   197 ms   202 ms  ip65-46-60-234.z60-46-65.customer.algx.net [65.46.60.234]
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26  ip65-46-60-234.z60-46-65.customer.algx.net [65.46.60.234]  reports: Destination net unreachable.
That’s from the Netherlands.
And the same result from a server in the U.S.:
$ traceroute -q1 crl.identrust.com
traceroute to crl.identrust.com (192.35.177.64), 30 hops max, 60 byte packets
 1  router1-nac.linode.com (207.99.1.13)  0.678 ms
 2  173.255.239.4 (173.255.239.4)  1.279 ms
 3  207.99.112.129 (207.99.112.129)  2.144 ms
 4  0.e1-2.tbr2.ewr.nac.net (209.123.10.113)  0.927 ms
 5  ae1-32.nyc41.ip4.gtt.net (173.205.45.185)  0.896 ms
 6  ae1-32.nyc41.ip4.gtt.net (173.205.45.185)  0.882 ms
 7  xe-1-3-3.nyc38.ip4.gtt.net (89.149.134.118)  1.348 ms
 8  207.88.13.34.ptr.us.xo.net (207.88.13.34)  70.397 ms
 9  207.88.13.34.ptr.us.xo.net (207.88.13.34)  70.409 ms
10  207.88.12.218.ptr.us.xo.net (207.88.12.218)  83.331 ms
11  207.88.12.218.ptr.us.xo.net (207.88.12.218)  83.356 ms
12  te-4-1-0.rar3.denver-co.us.xo.net (207.88.12.22)  63.044 ms
13  207.88.12.122.ptr.us.xo.net (207.88.12.122)  61.409 ms
14  207.88.12.122.ptr.us.xo.net (207.88.12.122)  61.469 ms
15  216.156.16.25.ptr.us.xo.net (216.156.16.25)  62.212 ms
16  ip65-46-60-234.z60-46-65.customer.algx.net (65.46.60.234)  62.998 ms
17  *
18  *
19  *
20  *
21  *
22  *
23  *
24  *
25  *
26  *
27  *
28  *
29  *
30  *
Someone on the #letsencrypt IRC channel just got this error from SSL Labs:
CRL ERROR: Processing failed: Read timed out [http://crl.identrust.com/DSTROOTCAX3CRL.crl]
But the test has been re-run again and doesn't show any errors.
For myself right now, from a few locations in the US, downloading the CRL takes a few seconds but works. From Atlanta and Orlando, well, curl has been trying to connect for over a minute.
Traceroute is similar to the one above: [mtr] f577d9a6 not found -- Usage: [-4/--inet] [-6/--inet6] [-b/--show-ips] [-B NUM/--bitpattern NUM] [-c COUNT/--report-cycles COUNT] [-e/--mpls] [-f NUM/--first-ttl NUM] [-i SECONDS/--interval SECONDS] [-m NUM/--max-ttl NUM] [-n/--no-dns] [-o ORDER/--order ORDER] [-u/--udp] [-v/--version] [-y NUM/--ipinfo NUM] [-z/--aslookup] HOSTNAME -- see https://mtr-atlanta.mn0.us/
It's about the same from locations that work too, e.g.: [mtr] 38a1fe5a not found -- Usage: [-4/--inet] [-6/--inet6] [-b/--show-ips] [-B NUM/--bitpattern NUM] [-c COUNT/--report-cycles COUNT] [-e/--mpls] [-f NUM/--first-ttl NUM] [-i SECONDS/--interval SECONDS] [-m NUM/--max-ttl NUM] [-n/--no-dns] [-o ORDER/--order ORDER] [-u/--udp] [-v/--version] [-y NUM/--ipinfo NUM] [-z/--aslookup] HOSTNAME -- see https://mtr-dallas.mn0.us/
Edit: Atlanta and Orlando both timed out after two minutes. I tried again and they both worked in about 3 seconds.
Edit: Trying Atlanta and Orlando again, sometimes it works after a few seconds, sometimes it doesn't.
Thanks for bringing this to our attention. We’re working on contacting the right folks at Identrust to look into this. I’ll update this thread once we know more.
Identrust has said there was a period of heavy traffic that may have affected their CRL distribution but believe it was transient.
Are you folks still experiencing issues?
I don’t want to make too many requests and overload them again, but right now it seems it takes ~2 seconds and doesn’t fail.
