I can not get a certificate - help
My domain is: tehcxweb.xyz
I ran this command:[tav@mail etc]$ sudo /usr/local/bin/certbot --apache --agree-tos --redirect --hsts --staple-ocsp --email tav@tehcxweb.xyz -d mail.tehcxweb.xyz
It produced this output:Domain: mail.tehcxweb.xyz
Detail: Invalid response from
http://mail.tehcxweb.xyz/.well-known/acme-challenge/dxr3QM6IEZtNTYBjlXp6MwiLJLvcNjdxvNtmxOUo44w
[77.79.135.68]: “\n\n400 Bad
Request\n\n
Bad Request</h1”
My web server is (include version):apache
redhat 8.1
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 1.3.0
my A record has the following form.
A mail → 77.79.135.68
Test A records pass.
I do not understand what the error is.
If you open http://mail.tehcxweb.xyz/ in a browser, you can see the rest of the error message on the page: Apache is configured to run HTTPS on port 80, the HTTP port, so connecting using HTTP doesn’t work.
If you open https://mail.tehcxweb.xyz:80/, you get a “Test Page for the Apache HTTP Server on Red Hat Enterprise Linux” page with a certificate for www.tehcxweb.xyz issued by GlobalSign.
If some kind of port forwarding is involved, make sure port 80 is forwarding to port 80 (and port 443 is forwarding to port 443).
If that’s not the issue, you need to examine to Apache configuration to find what’s wrong.
“sudo httpd -t -D DUMP_VHOSTS” can show a helpful summary of the virtual hosts.
VirtualHost configuration:
*:443 is a NameVirtualHost
default server r.crypexs.com (/etc/httpd/conf.d/r.crypexs.com.conf:1)
port 443 namevhost r.crypexs.com (/etc/httpd/conf.d/r.crypexs.com.conf:1)
alias www.r.crypexs.com
port 443 namevhost tehcxweb.xyz (/etc/httpd/conf.d/ssl.conf:40)
*:80 is a NameVirtualHost
default server tehcxweb.xyz (/etc/httpd/conf.d/le-redirect-tehcxweb.xyz.conf:1)
port 80 namevhost tehcxweb.xyz (/etc/httpd/conf.d/le-redirect-tehcxweb.xyz.conf:1)
port 80 namevhost mail.tehcxweb.xyz (/etc/httpd/conf.d/mail.tehcxweb.xyz.conf:1)
port 80 namevhost r.crypexs.com (/etc/httpd/conf.d/r.crypexs.com.conf:1)
port 80 namevhost tehcxweb.xyz (/etc/httpd/conf.d/tehcxweb.xyz.conf:1)
Here is the output of the command - but I don’t understand how to screw mail.tehcxweb.xyzhelp me please
[tav@mail conf.d]$ sudo httpd -t -D DUMP_VHOSTS
AH00112: Warning: DocumentRoot [/var/www/html/htdocs] does not exist
default server mail.tehcxweb.xyz (/etc/httpd/conf.d/mail.tehcxweb.xyz.conf:7)
port 443 namevhost mail.tehcxweb.xyz (/etc/httpd/conf.d/mail.tehcxweb.xyz.conf:7)
but keep getting the error
This is the fundamental problem and certbot --apache can't overcome this misconfiguration. It needs to be fixed before Certbot will be able to do anything useful.
