Certificate not validating
My domain is: kmqenterprisesllc.com
I ran this command:sudo certbot --apache
Domain: kmqenterprisesllc.com
Detail: 104.189.116.103: Invalid response from http://kmqenterprisesllc.com/.well-known/acme-challenge/gRaOIr4Th9fofqgaSIbOjL-kHXQHJdewgMj-SbB9LyY: 404
My web server is (include version): Chrome is up to date
Version 132.0.6834.111 (Official Build) (64-bit)
My hosting provider, if applicable, is:Ubuntu 22.04
Detail: (PUBLIC IP ADDRESS REMOVED: Invalid response from http://kmqenterprisesllc.com/.well-known/acme-challenge/CgNP3ePxWS3T93q7J7wudHB0d4eiziaRkYZZHD7mQfQ: 404
Welcome @kash1
Make sure HTTP requests of the form shown in the error message actually reach your Apache server. Because HTTP requests to your "home" page get a login page for MyCloud.
Based on a test HTTP request, I think your MyCloud may be replying to the Let's Encrypt HTTP challenge rather than your Apache. Usually we see a "Server: Apache" response header. It is not required but is very common. In any case, if the Let's Encrypt HTTP request was getting to your Apache properly you wouldn't get a 404 error.
curl -i http://kmqenterprisesllc.com/.well-known/acme-challenge/Test404
HTTP/1.1 404 Not Found
Content-Length: 196
Date: Sat, 25 Jan 2025 16:10:54 GMT
X-Frame-Options: sameorigin
HTTP to your "home" page shows
Thank you I'm configuring with your guidance now.
