Yes I saw that. I need to brush up on my commands to update the file but I can do that
Perhaps just use:
sudo nano /etc/apache2/sites-available/000-default.conf
sudo nano /etc/apache2/sites-available/000-default-le-ssl.conf
I do not see ServerAlias www.innovationdrones.com in the file, do I need to add this
Yep. Your're replacing the one default line with two new lines.
With the # in front?
The line you're replacing has the # (comment mark) in front. You don't want that in front of the new lines or they won't function.
Will this work:
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.innovationdrones.com
#ServerAlias www.innovationdrones.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =innovationdrones.com [OR]
RewriteCond %{SERVER_NAME} =www.innovationdrones.com
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
That shouldn't have a www.
<VirtualHost *:80>
ServerName innovationdrones.com
# modules, e.g.
RewriteEngine on
Did you make those changes to both files?
Yes I made the changes to both files
Did you run this?
sudo apachectl -k graceful
Do I need to stop and restart apache?
The graceful command I gave you handles the apache restart cleanly without loss.
Great So the Servername will be used now?
Yep.
What's the current output of:
sudo apachectl -S
VirtualHost configuration:
*:443 innovationdrones.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 innovationdrones.com (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Did you add the ServerAlias www.innovationdrones.com lines?
I thought they normally showed here. Hmm...
I think you did fine here.
Did you make the WordPress URL changes?
Yes looking at sudo cat /etc/apache2/sites-enabled/000-default.conf
ServerAlias www.xXinnovationdrones.com
# modules, e.g.
RewriteEngine on
vim: syntax=apache ts=4 sw=4 sts=4 sr noet ///
Where did the ServerAlias www.xXinnovationdrones.com come from?
