Are those x's actually there?
You might have hit 'x' while trying to exit the editor while hitting shift instead of control on your keyboard.
No worries though. Happens a hundred times a day.
Yea. I changed it and ran sudo apachectl -k graceful again
Now let's see:
sudo apachectl -S
VirtualHost configuration:
*:443 innovationdrones.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 innovationdrones.com (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Didn't figure it would change. Worth a shot though.
I finally got through to your https test site, but it's super slow.
Was it this slow before adding SSL?
No It was no this slow Is there a test I can run to see where the slow down is?
I ran it through SSL Labs...
https://www.ssllabs.com/ssltest/analyze.html?d=innovationdrones.com
I ran a GTMetrix test and it is telling the website is a A but it is running against the http
Both are saying A so it cannot be all bad. I would have thought the GTMetrix test would have shown a https. Maybe there is some redirect I need to do
Your redirects are perfect:
http://www.innovationdrones.com
301 Moved Permanently
https://www.innovationdrones.com/
https://innovationdrones.com/
200 OK
http://innovationdrones.com
200 OK
That is good to see
Do you see anything else we can do? At least you got me up and running in https
I wonder why? I am using Google domain and google cloud. I have a A type setup in both places, would that slow it down?
Did both # get removed?
Did one of the www get removed?
OK, the one with the xX ?
