Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: innovationdrones.com
I ran this command: https:innovationdrones.com
It produced this output: The connection was reset. ERR_CONNECTION_RESET
Hide details
My web server is (include version): Depian 9.13
My hosting provider, if applicable, is: Google Cloud
I can login root: yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.18.0
I installed the lets encrypt ssl cert and the installations went well but I get an error message when I run https://innovationdrones.com . Http://innovationdrones.com work fine.
Thanks
Welcome to the Let's Encrypt Community, Chuck
Looks like port 443 could be getting blocked by a firewall or router.
What is the output of:
sudo apachectl -S
For reference:
https://crt.sh/?q=innovationdrones.com
griffin:
sudo apachectl -S
VirtualHost configuration:
*:80 innovationdrones-vm-vm.us-central1-f.c.innovation-drones.internal (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
You have no port 443 vHost.
What are the outputs of:
sudo cat /etc/apache2/sites-enabled/000-default.conf
sudo ls -lRa /etc/apache2
Please put 3 backticks above and below each output, like this:
output
output:
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =innovationdrones.com [OR]
RewriteCond %{SERVER_NAME} =www.innovationdrones.com
</VirtualHost>
output:
/etc/apache2/mods-enabled:
total 8
drwxr-xr-x 2 root root 4096 Aug 26 22:04 .
drwxr-xr-x 8 root root 4096 Aug 26 22:05 ..
lrwxrwxrwx 1 root root 36 Aug 8 15:54 access_compat.load -> ../mods-available/access_compat.load
lrwxrwxrwx 1 root root 28 Aug 8 15:54 alias.conf -> ../mods-available/alias.conf
lrwxrwxrwx 1 root root 28 Aug 8 15:54 alias.load -> ../mods-available/alias.load
lrwxrwxrwx 1 root root 33 Aug 8 15:54 auth_basic.load -> ../mods-available/auth_basic.load
lrwxrwxrwx 1 root root 33 Aug 8 15:54 authn_core.load -> ../mods-available/authn_core.load
lrwxrwxrwx 1 root root 33 Aug 8 15:54 authn_file.load -> ../mods-available/authn_file.load
lrwxrwxrwx 1 root root 33 Aug 8 15:54 authz_core.load -> ../mods-available/authz_core.load
lrwxrwxrwx 1 root root 33 Aug 8 15:54 authz_host.load -> ../mods-available/authz_host.load
lrwxrwxrwx 1 root root 33 Aug 8 15:54 authz_user.load -> ../mods-available/authz_user.load
lrwxrwxrwx 1 root root 32 Aug 8 15:54 autoindex.conf -> ../mods-available/autoindex.conf
lrwxrwxrwx 1 root root 32 Aug 8 15:54 autoindex.load -> ../mods-available/autoindex.load
lrwxrwxrwx 1 root root 30 Aug 8 15:54 deflate.conf -> ../mods-available/deflate.conf
lrwxrwxrwx 1 root root 30 Aug 8 15:54 deflate.load -> ../mods-available/deflate.load
lrwxrwxrwx 1 root root 26 Aug 8 15:54 dir.conf -> ../mods-available/dir.conf
lrwxrwxrwx 1 root root 26 Aug 8 15:54 dir.load -> ../mods-available/dir.load
lrwxrwxrwx 1 root root 26 Aug 8 15:54 env.load -> ../mods-available/env.load
lrwxrwxrwx 1 root root 29 Aug 8 15:54 filter.load -> ../mods-available/filter.load
lrwxrwxrwx 1 root root 27 Aug 8 15:54 mime.conf -> ../mods-available/mime.conf
lrwxrwxrwx 1 root root 27 Aug 8 15:54 mime.load -> ../mods-available/mime.load
lrwxrwxrwx 1 root root 34 Aug 8 15:55 mpm_prefork.conf -> ../mods-available/mpm_prefork.conf
lrwxrwxrwx 1 root root 34 Aug 8 15:55 mpm_prefork.load -> ../mods-available/mpm_prefork.load
lrwxrwxrwx 1 root root 34 Aug 8 15:54 negotiation.conf -> ../mods-available/negotiation.conf
lrwxrwxrwx 1 root root 34 Aug 8 15:54 negotiation.load -> ../mods-available/negotiation.load
lrwxrwxrwx 1 root root 29 Aug 8 15:55 php7.4.conf -> ../mods-available/php7.4.conf
lrwxrwxrwx 1 root root 29 Aug 8 15:55 php7.4.load -> ../mods-available/php7.4.load
lrwxrwxrwx 1 root root 28 Aug 8 15:55 proxy.conf -> ../mods-available/proxy.conf
lrwxrwxrwx 1 root root 33 Aug 8 15:55 proxy_fcgi.load -> ../mods-available/proxy_fcgi.load
lrwxrwxrwx 1 root root 28 Aug 8 15:55 proxy.load -> ../mods-available/proxy.load
lrwxrwxrwx 1 root root 33 Aug 8 15:54 reqtimeout.conf -> ../mods-available/reqtimeout.conf
lrwxrwxrwx 1 root root 33 Aug 8 15:54 reqtimeout.load -> ../mods-available/reqtimeout.load
lrwxrwxrwx 1 root root 30 Aug 8 15:55 rewrite.load -> ../mods-available/rewrite.load
lrwxrwxrwx 1 root root 31 Aug 8 15:54 setenvif.conf -> ../mods-available/setenvif.conf
lrwxrwxrwx 1 root root 31 Aug 8 15:54 setenvif.load -> ../mods-available/setenvif.load
lrwxrwxrwx 1 root root 36 Aug 26 22:04 socache_shmcb.load -> ../mods-available/socache_shmcb.load
lrwxrwxrwx 1 root root 26 Aug 26 22:04 ssl.conf -> ../mods-available/ssl.conf
lrwxrwxrwx 1 root root 26 Aug 26 22:04 ssl.load -> ../mods-available/ssl.load
lrwxrwxrwx 1 root root 29 Aug 8 15:54 status.conf -> ../mods-available/status.conf
lrwxrwxrwx 1 root root 29 Aug 8 15:54 status.load -> ../mods-available/status.load
/etc/apache2/sites-available:
total 28
drwxr-xr-x 2 root root 4096 Aug 26 22:05 .
-rw-r--r-- 1 root root 1528 Aug 26 22:05 000-default.conf
-rw-r--r-- 1 root root 1593 Aug 26 22:05 000-default-le-ssl.conf
-rw-r--r-- 1 root root 6338 Jun 16 2019 default-ssl.conf
-rw-r--r-- 1 root root 82 Aug 8 15:55 wordpress.conf
/etc/apache2/sites-enabled:
total 8
lrwxrwxrwx 1 root root 35 Aug 8 15:54 000-default.conf -> ../sites-available/000-default.conf
lrwxrwxrwx 1 root root 52 Aug 26 22:04 000-default-le-ssl.conf -> /etc/apache2/sites-available/000-default-le-ssl.conf
lrwxrwxrwx 1 root root 33 Aug 8 15:55 wordpress.conf -> ../sites-available/wordpress.conf
Please edit your post to add the three backticks like I mentioned. Otherwise a chunk of your configuration is missing due to the community site treating it as HTML.
I'm not a leader , so I can't do it for you.
I will do that but did the commands you sent me fix the issue. https://innovationdrones.com is working but it is slow.
I wanted to fix your vHosts first then run certbot.
griffin
August 26, 2021, 10:18pm
10
Check your two WordPress URLs while you're at it:
Make certain that they both begin with https .
griffin
August 26, 2021, 10:23pm
11
Change this line in both /etc/apache2/sites-enabled/000-default.conf and /etc/apache2/sites-enabled/000-default-le-ssl.conf:
to these two lines:
ServerName innovationdrones.com
ServerAlias www.innovationdrones.com
Then run this:
sudo apachectl -k graceful
griffin
August 26, 2021, 10:24pm
12
Heya @rg305 !
Things are progressing beautifully here.
griffin
August 26, 2021, 10:25pm
13
I'm suspecting the WordPress backend configuration to be the final piece.
rg305
August 26, 2021, 10:26pm
14
@griffin , I see that.
I went ahead and added the ``` where they seemed fitting.
griffin
15
Awesome! That helps much!
griffin
August 26, 2021, 10:29pm
17
That's because he has no ServerName in his vHost.
This is the VM host name:
So I need to add a Server Name
griffin
August 26, 2021, 10:31pm
19
I think this configuration file might have some proxy directives/configuration in it:
griffin
August 26, 2021, 10:32pm
20
Yep. I mentioned that here:
