This page does not redirect correctly - ERR_CONNECTION_REFUSED
I installed a Let's Encrypt certificate following the instructions on
Getting Started - Let's Encrypt and Certbot - Ubuntubionic Apache becasue my server is Apache on Ubuntu 18.04.
All right (look at the attachment
) but the site now replies continuously "This page does not redirect correctly"
To restart muy site I removed the certificate.
Now I have ERR_CONNECTION_REFUSED !
My domain is: nomadeway.com
I ran this command: look at the attachement
It produced this output:look at the attachement
My web server is (include version): UBUNTU 18.04
My hosting provider, if applicable, is: OVH
I can login to a root shell on my machine (yes or no, or I don't know): YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): I'm using SSH
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.16.0
What's the output of:
sudo apachectl -S
Hi Osiris
this is the cmd's reply
VirtualHost configuration:
*:80 is a NameVirtualHost
default server nomadeway.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:43)
port 80 namevhost nomadeway.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:43)
port 80 namevhost nomadeway.com (/etc/apache2/sites-enabled/000-default.conf:1)
*:443 is a NameVirtualHost
default server nomadeway.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
port 443 namevhost nomadeway.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
port 443 namevhost vps773572.ovh.net (/etc/apache2/sites-enabled/default-ssl.conf:2)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Please put three backticks (```) above and below all outputs and contents of files. I.e.:
contents of file or output
Could you paste the output of the files:
and
content of /etc/apache2/sites-enabled/000-default.conf`
<VirtualHost *:80>
	# specifies what hostname must appear in the request's Host: header to
	ServerName nomadeway.com
	Redirect permanent / https://nomadeway.com/
	#DocumentRoot /var/www/nomade
	# error, crit, alert, emerg.
	# modules, e.g.
	#LogLevel info ssl:warn
	#:wq following line enables the CGI configuration for this host only
<Directory /var/www/nomadeway/>
    AllowOverride All
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =nomadeway.com
</VirtualHost>
content of /etc/apache2/sites-enabled/000-default-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
	#DocumentRoot /var/www/nomadeway
	# modules, e.g.
    AllowOverride All
</Directory>
SSLCertificateFile /etc/letsencrypt/live/nomadeway.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/nomadeway.com/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
	# modules, e.g.
    AllowOverride All
</Directory>
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =nomadeway.com
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
</IfModule>
Those aren't the correct backticks I'm afraid, you can copy/paste them from my post above. If you could correct them, it would be very helpful, it's rather hard to read, especially as the end tags are missing now.
Also perhaps also the contents of /etc/apache2/sites-enabled/default-ssl.conf please, missed that one earlier. Probably not the issue looking at the hostname but you never know.
We could try to comment out all the current redirects we see here by adding a # in front of the directive. I see two Redirect permanent ... statements and also the RewriteCond and RewriteRule.
If we disable all the redirects in the Apache configuration files and your site still redirects from HTTPS to HTTPS, we'd need to check something else entirely.
Contents of `/etc/apache2/sites-enabled/default-ssl.conf
	<VirtualHost _default_:443>
		# modules, e.g.
		#   SSL Engine Switch:
		#   Enable/Disable SSL for this virtual host.
		SSLEngine off
		#   A self-signed (snakeoil) certificate can be created by installing
		#   the ssl-cert package. See
		#   /usr/share/doc/apache2/README.Debian.gz for more info.
		#   If both key and certificate are stored in the same file, only the
		#   SSLCertificateFile directive is needed.
		#SSLCertificateFile	/etc/letsencrypt/live/nomadeway.com/fullchain.pem
		#SSLCertificateKeyFile /etc/letsencrypt/live/nomadeway.com/privkey.pem
		#   Server Certificate Chain:
		#   Point SSLCertificateChainFile at a file containing the
		#   concatenation of PEM encoded CA certificates which form the
		#   certificate chain for the server certificate. Alternatively
		#   the referenced file can be the same as SSLCertificateFile
		#   when the CA certificates are directly appended to the server
		#   certificate for convinience.
		#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
		#   Certificate Authority (CA):
		#   Set the CA certificate verification path where to find CA
		#   certificates for client authentication or alternatively one
		#   huge file containing all of them (file must be PEM encoded)
		#   Note: Inside SSLCACertificatePath you need hash symlinks
		#		 to point to the certificate files. Use the provided
		#		 Makefile to update the hash symlinks after changes.
		#SSLCACertificatePath /etc/ssl/certs/
		#SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt
    AllowOverride All
</Directory>
		#   Certificate Revocation Lists (CRL):
		#   Set the CA revocation path where to find CA CRLs for client
		#   authentication or alternatively one huge file containing all
		#   of them (file must be PEM encoded)
		#   Note: Inside SSLCARevocationPath you need hash symlinks
		#SSLCARevocationPath /etc/apache2/ssl.crl/
		#SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl
		#   Client Authentication (Type):
		#   Client certificate verification type and depth.  Types are
		#   none, optional, require and optional_no_ca.  Depth is a
		#   number which specifies how deeply to verify the certificate
		#   issuer chain before deciding the certificate is not valid.
		#SSLVerifyClient require
		#SSLVerifyDepth  10
		#   SSL Engine Options:
		#   Set various options for the SSL engine.
		#   o FakeBasicAuth:
		#	 Translate the client X.509 into a Basic Authorisation.  This means that
		#	 the standard Auth/DBMAuth methods can be used for access control.  The
		#	 user name is the `one line' version of the client's X.509 certificate.
		#	 Note that no password is obtained from the user. Every entry in the user
		#	 file needs this password: `xxj31ZMTZzkVA'.
		#   o ExportCertData:
		#	 This exports two additional environment variables: SSL_CLIENT_CERT and
		#	 SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
		#	 server (always existing) and the client (only existing when client
		#	 authentication is used). This can be used to import the certificates
		#	 into CGI scripts.
		#   o StdEnvVars:
		#	 This exports the standard SSL/TLS related `SSL_*' environment variables.
		#	 Per default this exportation is switched off for performance reasons,
		#	 because the extraction step is an expensive operation and is usually
		#	 useless for serving static content. So one usually enables the
		#	 exportation for CGI and SSI requests only.
		#   o OptRenegotiate:
		#	 This enables optimized SSL connection renegotiation handling when SSL
		#	 directives are used in per-directory context.
		#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
		<FilesMatch "\.(cgi|shtml|phtml|php)$">
				SSLOptions +StdEnvVars
		</FilesMatch>
		<Directory /usr/lib/cgi-bin>
		</Directory>
		#   SSL Protocol Adjustments:
		#   The safe and default but still SSL/TLS standard compliant shutdown
		#   approach is that mod_ssl sends the close notify alert but doesn't wait for
		#   the close notify alert from client. When you need a different shutdown
		#   approach you can use one of the following variables:
		#   o ssl-unclean-shutdown:
		#	 This forces an unclean shutdown when the connection is closed, i.e. no
		#	 SSL close notify alert is send or allowed to received.  This violates
		#	 the SSL/TLS standard but is needed for some brain-dead browsers. Use
		#	 this when you receive I/O errors because of the standard approach where
		#	 mod_ssl sends the close notify alert.
		#   o ssl-accurate-shutdown:
		#	 This forces an accurate shutdown when the connection is closed, i.e. a
		#	 SSL close notify alert is send and mod_ssl waits for the close notify
		#	 alert of the client. This is 100% SSL/TLS standard compliant, but in
		#	 practice often causes hanging connections with brain-dead browsers. Use
		#	 this only for browsers where you know that their SSL implementation
		#	 works correctly.
		#   Notice: Most problems of broken clients are also related to the HTTP
		#   keep-alive facility, so you usually additionally want to disable
		#   keep-alive for those clients, too. Use variable "nokeepalive" for this.
		#   Similarly, one has to force some clients to use HTTP/1.0 to workaround
		#   their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
		#   "force-response-1.0" for this.
		# BrowserMatch "MSIE [2-6]" \
		#		nokeepalive ssl-unclean-shutdown \
		#		downgrade-1.0 force-response-1.0
	</VirtualHost>
</IfModule>
Content of /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
	# modules, e.g.
    AllowOverride All
</Directory>
RewriteEngine on
</VirtualHost>
Content of /etc/apache2/sites-enabled/000-default-le-ssl.conf
<VirtualHost *:443>
	# modules, e.g.
    AllowOverride All
</Directory>
</VirtualHost>
</IfModule>
<VirtualHost *:80>
	# modules, e.g.
    AllowOverride All
</Directory>
RewriteEngine on
</VirtualHost>
</IfModule>
Content of /etc/apache2/sites-enabled/default-ssl.conf
		# modules, e.g.
		SSLEngine off
    AllowOverride All
</Directory>
		#SSLVerifyDepth  10
		#   o FakeBasicAuth:
		#   o ExportCertData:
		#	 into CGI scripts.
		#   o StdEnvVars:
		#   o OptRenegotiate:
		</FilesMatch>
		</Directory>
		#	 works correctly.
	</VirtualHost>
</IfModule>
It seems certbot forgot to remove the Redirect directive from your HTTPS virtualhost when it copied it from the HTTP virtualhost.. You should remove that one.
Also, I'm puzzled why there is an extra copy of the <VirtualHost *:80> in 000-default-le-ssl.conf? You should probably remove that one too.
And a last thing: you probably want to un-comment the DocumentRoot directive from your <VirtualHost *:443> section.
Did this duplicate name:port get addressed?:
Yep:
Here it is summarized:
Content updated of /etc/apache2/sites-enabled/000-default-le-ssl.conf (I commented rather than delete)
<VirtualHost *:443>
#	Redirect permanent / https://nomadeway.com/
	# modules, e.g.
    AllowOverride All
</Directory>
</VirtualHost>
</IfModule>
#<IfModule mod_ssl.c>
#<VirtualHost *:80>
#	ServerName nomadeway.com
#	ServerAdmin webmaster@localhost
	# modules, e.g.
#	ErrorLog ${APACHE_LOG_DIR}/error.log
#	CustomLog ${APACHE_LOG_DIR}/access.log combined
#<Directory /var/www/nomadeway/>
#    AllowOverride All
#</Directory>
#RewriteEngine on
#</VirtualHost>
#</IfModule>
Content of updatetd /etc/apache2/sites-enabled/default-ssl.conf
#		DocumentRoot /var/www/nomadeway
		# modules, e.g.
		SSLEngine off
#    AllowOverride All
#</Directory>
		#SSLVerifyDepth  10
		#   o FakeBasicAuth:
		#   o ExportCertData:
		#	 into CGI scripts.
		#   o StdEnvVars:
		#   o OptRenegotiate:
		</FilesMatch>
		</Directory>
		#	 works correctly.
	</VirtualHost>
</IfModule>
Content updated of /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
	# modules, e.g.
    AllowOverride All
</Directory>
RewriteEngine on
</VirtualHost>
Now I have:
# Not Found
The requested URL was not found on this server.
Apache/2.4.29 (Ubuntu) Server at nomadeway.com Port 443
That's not really a good/better thing here.
If you need the memory of it, copy it to another location or another name (not in use).
But delete anything/everything that you don't need.
<VirtualHost *:443>
	# modules, e.g.
    AllowOverride All
</Directory>
</VirtualHost>
</IfModule>
Content updated of /etc/apache2/sites-enabled/default-ssl.conf
		# modules, e.g.
		SSLEngine off
		#SSLVerifyDepth  10
		#   o FakeBasicAuth:
		#   o ExportCertData:
		#	 into CGI scripts.
		#   o StdEnvVars:
		#   o OptRenegotiate:
		</FilesMatch>
		</Directory>
		#	 works correctly.
	</VirtualHost>
</IfModule>
Result:
Not Found
This is the correct 000-default-le-ssl.conf
<VirtualHost *:443>
	# modules, e.g.
    AllowOverride All
</Directory>
</VirtualHost>
</IfModule>
Now all is ok
Thank you, Osiris for suggestions
