Https not working after 'succesful' certbot --apache operation
quickwebnav.com
-ubuntu-trusty-64:~$ sudo certbot --apache
Enter email address (used for urgent renewal and security notices) (Enter ‘c’ to
cancel): inman.turbo@gmail.com
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/©ancel: A
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let’s Encrypt project and the non-profit
organization that develops Certbot? We’d like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: Y
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): quickwebnav.com
http-01 challenge for quickwebnav.com
Waiting for verification…
Created an SSL vhost at /etc/apache2/sites-available/000-default-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/000-default-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/000-default-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Congratulations! You have successfully enabled https://quickwebnav.com
https://www.ssllabs.com/ssltest/analyze.html?d=quickwebnav.com
    /etc/letsencrypt/live/quickwebnav.com/fullchain.pem
    /etc/letsencrypt/live/quickwebnav.com/privkey.pem
    Your cert will expire on 2019-07-14. To obtain a new or tweaked
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
  • Your account credentials have been saved in your Certbot
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/quickwebnav.com.conf
new certificate deployed with reload of apache server; fullchain is
/etc/letsencrypt/live/quickwebnav.com/fullchain.pem (success)
|Apache Version|Apache/2.4.7 (Ubuntu)|
|Apache API Version|20120211|
|Server Administrator|webmaster@localhost|
|Hostname:Port|quickwebnav.com:80|
|Loaded Modules|core mod_so mod_watchdog http_core mod_log_config mod_logio mod_version mod_unixd mod_access_compat mod_alias mod_auth_basic mod_authn_core mod_authn_file mod_authz_core mod_authz_host mod_authz_user mod_autoindex mod_deflate mod_dir mod_env mod_filter mod_mime prefork mod_negotiation mod_php7 mod_rewrite mod_setenvif mod_socache_shmcb mod_ssl mod_status|
The operating system my web server runs on is (include version): Ubunto 14.04 (Trusty)
My hosting provider, if applicable, is: N/A? Domain is purchased through godaddy but the dns is pointed to a non-godaddy IP. Note: I host other domains at godaddy and have a cert I can use there, but I want to host this one elsewhere.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Hi @inman.turbo
checking your domain (via https://check-your-website.server-daten.de/?q=quickwebnav.com ):
• http://quickwebnav.com/
96.89.79.178 200 0.310 H
• http://www.quickwebnav.com/
96.89.79.178 200 0.303 H
• https://quickwebnav.com/
96.89.79.178 -4 0.573 W
SendFailure - The underlying connection was closed: An unexpected error occurred on a send. Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
• https://www.quickwebnav.com/
96.89.79.178 -4 0.584 W
Google CT shows the new certificate (crt.sh not), so you have created a new certificate.
Looks like Certbot doesn't understand your configuration.
Uh, that's very old.
What says
certbot certificates
apachectl configtest
apachectl fullstatus
apachectl -S
Hello JuergenAur, thanks for the quick response.
sudo certbot certificates
Found the following certs:
Certificate Name: quickwebnav.com
Domains: quickwebnav.com
Expiry Date: 2019-07-14 14:46:39+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/quickwebnav.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/quickwebnav.com/privkey.pem
sudo apachectl configtest
syntax ok
Apache Server Status for localhost (via 127.0.0.1)
Server Version: Apache/2.4.7 (Ubuntu) OpenSSL/1.0.1f
Server MPM: prefork
Server Built: Apr 3 2019 18:04:25
Current Time: Monday, 15-Apr-2019 19:25:46 UTC
Restart Time: Monday, 15-Apr-2019 15:35:01 UTC
Parent Server Config. Generation: 8
Parent Server MPM Generation: 7
Server uptime: 3 hours 50 minutes 44 seconds
Server load: 0.00 0.01 0.05
Total accesses: 84 - Total Traffic: 196 kB
CPU Usage: u.01 s.05 cu0 cs0 - .000433% CPU load
.00607 requests/sec - 14 B/second - 2389 B/request
1 requests currently being processed, 6 idle workers
__W.........................................................
Scoreboard Key:
"_" Waiting for Connection, "S" Starting up, "R" Reading Request,
"W" Sending Reply, "K" Keepalive (read), "D" DNS Lookup,
"C" Closing connection, "L" Logging, "G" Gracefully finishing,
"I" Idle cleanup of worker, "." Open slot with no current process
Srv PID Acc M CPU SS Req Conn Child Slot Client VHost Request
0-7 26130 0/8/25 _ 0.01 5487 0 0.0 0.01 0.01 10.0.2.2 quickwebnav.com:80 GET /.well-known/acme-challenge/check-your-website-dot-server-d
1-7 26131 0/9/16 _ 0.01 7936 1 0.0 0.03 0.03 10.0.2.2 quickwebnav.com:80 HEAD / HTTP/1.1
2-7 26132 0/10/ _ 0.02 4982 1 0.0 0.06 0.08 10.0.2.2 quickwebnav.com:80 GET / HTTP/1.1
17
3-7 26133 0/6/10 _ 0.01 5489 1 0.0 0.04 0.04 10.0.2.2 quickwebnav.com:80 GET / HTTP/1.1
4-7 26134 0/2/8 W 0.00 0 0 0.0 0.00 0.00 127.0.0.1 quickwebnav.com:80 GET /server-status HTTP/1.0
5-7 26317 0/7/8 _ 0.01 4982 2 0.0 0.02 0.02 10.0.2.2 quickwebnav.com:80 GET / HTTP/1.1
Srv Child Server number - generation
PID OS process ID
Acc Number of accesses this connection / this child / this slot
M Mode of operation
CPU CPU usage, number of seconds
SS Seconds since beginning of most recent request
Req Milliseconds required to process most recent request
Conn Kilobytes transferred this connection
Child Megabytes transferred this child
Slot Total megabytes transferred this slot
SSL/TLS Session Cache Status:
cache type: SHMCB, shared memory: 512000 bytes, current entries: 0
subcaches: 32, indexes per subcache: 88
index usage: 0%, cache usage: 0%
total entries stored since starting: 0
total entries replaced since starting: 0
total entries expired since starting: 0
total (pre-expiry) entries scrolled out of the cache: 0
total retrieves since starting: 0 hit, 0 miss
total removes since starting: 0 hit, 0 miss
Apache/2.4.7 (Ubuntu) Server at localhost Port 80
apachectl -S
VirtualHost configuration:
*:443 quickwebnav.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 quickwebnav.com (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Main DocumentRoot: "/var/www"
Mutex default: dir="/var/lock/apache2" mechanism=fcntl
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Your main configuration looks ok.
But https doesn't work.
Do you have some "untypical definitions"?
What's the content of that file?
Has your Apache-log some additional informations?
<IfModule mod_ssl.c>
<VirtualHost *:443>
        # specifies what hostname must appear in the request's Host: header to
        #ServerName www.example.com
        DocumentRoot /var/www/html
        # error, crit, alert, emerg.
        # modules, e.g.
        #LogLevel info ssl:warn
ServerName quickwebnav.com
SSLCertificateFile /etc/letsencrypt/live/quickwebnav.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/quickwebnav.com/privkey.pem
</VirtualHost>
</IfModule>
error log shows nothing of interest as far as I can tell. ServerName and restart notices.
I’ve upgraded apache2 to latest version (clean install) and reinstalled with certbot (clean as well) the cert. Didn’t change anything. How do I get newer API?
[Mon Apr 15 19:50:45.909383 2019] [mpm_event:notice] [pid 12080:tid 140487727916928] AH00489: Apache/2.4.7 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 19:50:45.909458 2019] [core:notice] [pid 12080:tid 140487727916928] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 19:51:31.844096 2019] [mpm_event:notice] [pid 12080:tid 140487727916928] AH00491: caught SIGTERM, shutting down
[Mon Apr 15 19:51:32.897664 2019] [mpm_prefork:notice] [pid 19620] AH00163: Apache/2.4.7 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 19:51:32.897726 2019] [core:notice] [pid 19620] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 19:51:33.112636 2019] [mpm_prefork:notice] [pid 19620] AH00169: caught SIGTERM, shutting down
[Mon Apr 15 19:51:34.185557 2019] [mpm_prefork:notice] [pid 19694] AH00163: Apache/2.4.7 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 19:51:34.185602 2019] [core:notice] [pid 19694] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 19:51:35.684417 2019] [mpm_prefork:notice] [pid 19694] AH00169: caught SIGTERM, shutting down
[Mon Apr 15 19:51:36.739917 2019] [mpm_prefork:notice] [pid 19748] AH00163: Apache/2.4.7 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 19:51:36.739961 2019] [core:notice] [pid 19748] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 19:52:00.819957 2019] [mpm_prefork:notice] [pid 19748] AH00169: caught SIGTERM, shutting down
[Mon Apr 15 19:52:01.870184 2019] [mpm_prefork:notice] [pid 23201] AH00163: Apache/2.4.7 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 19:52:01.870241 2019] [core:notice] [pid 23201] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 19:56:50.873448 2019] [mpm_prefork:notice] [pid 23201] AH00169: caught SIGTERM, shutting down
[Mon Apr 15 19:56:51.933652 2019] [mpm_prefork:notice] [pid 30919] AH00163: Apache/2.4.7 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 19:56:51.933690 2019] [core:notice] [pid 30919] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 20:06:46.360422 2019] [mpm_prefork:notice] [pid 30919] AH00169: caught SIGTERM, shutting down
[Mon Apr 15 20:06:47.429755 2019] [mpm_prefork:notice] [pid 10935] AH00163: Apache/2.4.39 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 20:06:47.429797 2019] [core:notice] [pid 10935] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 20:15:05.540983 2019] [mpm_prefork:notice] [pid 10935] AH00171: Graceful restart requested, doing restart
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 2603:3001:7b2:c000:a00:27ff:fec2:c3b1. Set the 'ServerName' directive globally to suppress this message
[Mon Apr 15 20:15:05.559340 2019] [mpm_prefork:notice] [pid 10935] AH00163: Apache/2.4.39 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 20:15:05.559351 2019] [core:notice] [pid 10935] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 20:15:11.914399 2019] [mpm_prefork:notice] [pid 10935] AH00171: Graceful restart requested, doing restart
[Mon Apr 15 20:15:11.940473 2019] [mpm_prefork:notice] [pid 10935] AH00163: Apache/2.4.39 (Ubuntu) configured -- resuming normal operations
[Mon Apr 15 20:15:11.940485 2019] [core:notice] [pid 10935] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 20:15:14.802119 2019] [mpm_prefork:notice] [pid 10935] AH00171: Graceful restart requested, doing restart
[Mon Apr 15 20:15:14.819377 2019] [mpm_prefork:notice] [pid 10935] AH00163: Apache/2.4.39 (Ubuntu) OpenSSL/1.1.1b configured -- resuming normal operations
[Mon Apr 15 20:15:14.819388 2019] [core:notice] [pid 10935] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 20:15:33.596426 2019] [mpm_prefork:notice] [pid 10935] AH00169: caught SIGTERM, shutting down
[Mon Apr 15 20:15:34.665393 2019] [mpm_prefork:notice] [pid 11138] AH00163: Apache/2.4.39 (Ubuntu) OpenSSL/1.1.1b configured -- resuming normal operations
[Mon Apr 15 20:15:34.665436 2019] [core:notice] [pid 11138] AH00094: Command line: '/usr/sbin/apache2'
[Mon Apr 15 20:27:21.326836 2019] [mpm_prefork:notice] [pid 11138] AH00171: Graceful restart requested, doing restart
[Mon Apr 15 20:27:21.344557 2019] [mpm_prefork:notice] [pid 11138] AH00163: Apache/2.4.39 (Ubuntu) OpenSSL/1.1.1b configured -- resuming normal operations
[Mon Apr 15 20:27:21.344569 2019] [core:notice] [pid 11138] AH00094: Command line: '/usr/sbin/apache2'
Access.log:
10.0.2.2 - - [15/Apr/2019:20:00:33 +0000] "GET /index.php HTTP/1.1" 200 23690 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36"
10.0.2.2 - - [15/Apr/2019:20:06:54 +0000] "GET /index.php HTTP/1.1" 200 23696 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36"
10.0.2.2 - - [15/Apr/2019:20:15:08 +0000] "GET /.well-known/acme-challenge/eMX96QvrT-Mw0-fmRnK9srSlHkLbCEEV_rGc50cMjMw HTTP/1.1" 200 308 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
10.0.2.2 - - [15/Apr/2019:20:15:52 +0000] "GET /index.php HTTP/1.1" 200 23709 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36"
10.0.2.2 - - [15/Apr/2019:20:20:04 +0000] "GET / HTTP/1.1" 200 3539 "-" "Mozilla/5.0 (Windows NT 6.2; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36"
10.0.2.2 - - [15/Apr/2019:20:22:05 +0000] "GET /index.php HTTP/1.1" 200 23709 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36"
That's your http log, that's not relevant.
Checking with OpenSSL there is an error:
write:errno=10054
has some additional informations.
Something in your configuration is bad.
Yes there must be. I just don't know what it may be. Http works fine and certbot configured https automatically without errors. Where might I look for additional clues?
I've tried this with Ubunto and CentOs and both with the same result. No https. Does it matter that this is VM? But all ports are forwarding fine through host and port tests come back fine.
Port [21]is open on 96.89.79.178.
Port [22] is closed on 96.89.79.178.
Port [23] is closed on 96.89.79.178.
Port [25] is closed on 96.89.79.178.
Port [53] is closed on 96.89.79.178.
Port [80] is open on [96.89.79.178].
Port [110]is closed on 96.89.79.178.
Port [115] is closed on 96.89.79.178.
Port [135] is closed on 96.89.79.178.
Port [139] is closed on 96.89.79.178.
Port [143] is closed on 96.89.79.178.
Port [194] is closed on 96.89.79.178.
Port [443] is open on 96.89.79.178.
Port [445] is closed on 96.89.79.178.
Port [1433] is closed on 96.89.79.178.
Port [3306] is open on 96.89.79.178.
Port [3389] is closed on 96.89.79.178.
Port [5632]is closed on 96.89.79.178.
Port [5900] is closed on 96.89.79.178.
Port [6112] is closed on 96.89.79.178.
