My domain is: yppgi.org
I ran this command: sudo certbot --nginx -d yppgi.org -d www.yppgi.org
" No matching insecure server blocks listening on port 80 found.
Your existing certificate has been successfully renewed, and the new certificate
has been installed. "
My web server is (include version): Ubuntu 18.04.4 LTS
The operating system my web server runs on is (include version): Ubuntu 18.04.4 LTS
My hosting provider, if applicable, is: WORDPRESS
I can login to a root shell on my machine (yes or no, or I don’t know): YES
Please help me with this. It has been almost 4 days now. going confused why my website can’t run on HTTPS.
here’s my config on ngix/sites-available/
listen 80;
listen 443 ssl;
server_name yppgi.org www.yppgi.org;
ssl on;
ssl_certificate /etc/letsencrypt/live/yppgi.org/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/yppgi.org/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
proxy_pass http://192.168.99.101;
proxy_http_version 1.1;
proxy_set_header Connection ‘upgrade’;
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
proxy_redirect off;
proxy_set_header X-Forwarded-Ssl $scheme;
