My domain is: http://indiasaplings.com/
I ran this command: sudo certbot --nginx -d indiasaplings.com -d www.indiasaplings.com
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/indiasaplings.com/fullchain.pem
/etc/letsencrypt/live/indiasaplings.com/privkey.pem
Your cert will expire on 2019-12-29. To obtain a new or tweaked
with the “certonly” option. To non-interactively renew all of
your certificates, run “certbot renew”
- CMS: Mazento 2
- Web Server: Nginx
- OS: Ubuntu 18.04
- Hosting: AWS
Here is my server block:-
# if ($host = indiasaplings.com) {
# return 301 https://$host$request_uri;
# } # managed by Certbot
listen 80;
server_name indiasaplings.com www.indiasaplings.com;
# return 301 https://indiasaplings.com$request_uri;
set $MAGE_ROOT /var/www/html/sm/sm_shopee;
set $MAGE_DEBUG_SHOW_ARGS 1;
include /etc/nginx/m2/m231.conf;
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/indiasaplings.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/indiasaplings.com/privkey.pem; # managed by Certbot
listen 443 ssl default_server;
listen [::]:443 ssl default_server;
set $MAGE_ROOT /var/www/hmtl/sm/sm_shopee;
I am not able to open my site on HTTPS:// even after installing and configuring Let’s Encrypt. Please guide, Thank you!
