How to upgrade certbot (installed using snap) on Ubuntu 20.04?
Open LIte Speed
Ubuntu 20.04
certbot 0.40.0
Hi guys, I installed certbot following the installation guide with snap. But I can not upgrade my certbot . The commands apt update , apt upgrade only upgrade the other packages , and "apt list --upgradable" does not list certbot. Am I missing something?? How can I confirm if I have added certbot repositories??
thanks for your helps friends.
Versio 0.40.0 really sounds like a version installed using apt and not using snap. Did you remove all non-snap versions of Certbot as instructed by the Certbot instruction guide?
Further more, if I understand Managing updates | Snapcraft documentation correctly, snaps are updated automatically.
Thanks Osiris for your comment, but I used these commands to install certbot
  1. Install / Verify “snapd” instalation.
sudo snap install core; sudo snap refresh core
  1. Delete any “certbot” installation on server
sudo apt-get remove certbot
  1. Fresh install of certbot
sudo snap install –classic certbot
  1. Testing that certbot can be executed
sudo ln -s /snap/bin/certbot /usr/bin/certbot
And as you say, it suppose snaps keeps certbot updated but it is not working. I am running this on AWS EC2 instance Ubuntu 20.04.
You may have multiple versions of certbot installed.
What shows?:
certbot --version
which certbot
find / -name certbot
Thanks @rg305 , this is the output
certbot --version
certbot 0.40.0
which certbot
/usr/bin/certbot
sudo find / -name certbot
[sudo] password for user:
/usr/share/doc/certbot
/usr/lib/python3/dist-packages/certbot
/usr/bin/certbot
/etc/cron.d/certbot
/etc/logrotate.d/certbot
I don't see any /snap/lib/certbot in that list.
Only the old certbot 0.40.0 [installed from apt].
You say you ran those commands [post #3], but the system doesn't show any of that.
Did you happen to restore from a previous snapshot?
@rg305 , thanks for your time. I am sure I did run those command because was the guide I used to install my first certificate, at this moment I have 7 certs running on this server. To move forward, should I run the steps of the guide mentioned above to install certbot snap version?? Is there risk of conflicts with my current certificates that I am using?
  • Install snap core,
  • apt-get remove certbot
  • snap install -classic certbot
  • ln -s /snap/bin/certbot /usr/bin/certbot
If they are being managed by certbot, no.
It is upwards compatible.
My certs were installed and managed by certbot. Finally, I re-installed certbot as the guide, for sure I missed something last time but I think it is looking good now. Thanks @rg305 .
certbot --version
certbot 1.32.0
which certbot
/usr/bin/certbot
/usr/bin/certbot
/var/snap/certbot
/snap/certbot
/snap/certbot/2511/bin/certbot
/snap/certbot/2511/lib/python3.8/site-packages/certbot
/snap/bin/certbot
/root/snap/certbot
/etc/cron.d/certbot
