Issues updating certbot
Hi there,
I'm having issue renewing my certificate and I think it maybe due to the version of certbot I'm using which is 1.16.0, however, I am having a big problem removing it as it isn't showing up in apt.
I can see that in the newer versions it uses snap which I don't have installed on the server so I must have installed it a different way. If anyone can help me with how to uninstall the old version and install the snap version it would be appreciated.
I don't want to assume the issue I have with the renewing the certificate is anything until I have updated certbot first.
Thanks,
Ed
That probably is not the best way forward. While updating Certbot and using the snap install method is good that will just introduce other possible problems.
V1.16 is not horribly old so it would be better to evaluate what is going wrong and go from there.
What is the result of this command?
sudo certbot renew --dry-run
Also, we need to know more answers from the form you should have been shown. Different systems require different advice.
My domain is: app.veeambp.com
Processing /etc/letsencrypt/renewal/app.veeambp.com.conf
Renewing an existing certificate for app.veeambp.com
Domain: app.veeambp.com
Detail: 2a02:4780:b:1321:0:2a26:c84a:8: Invalid response from http://app.veeambp.com/.well-known/acme-challenge/maXwJNqy6K0ZPvZo5T_8aW81-0HckgL1z-LD2N8ui50: 404
Failed to renew certificate app.veeambp.com with error: Some challenges have failed.
/etc/letsencrypt/live/app.veeambp.com/fullchain.pem (failure)
My web server is (include version): nginx 1.14.0
The operating system my web server runs on is (include version): Ubuntu 18.04.6 LTS
My hosting provider, if applicable, is: Hostlinger
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): I don't have direct access to this someone else does, I'd need to check if still relevant.
Thanks,
Ed
Here is the output of that comman;
Simulating renewal of an existing certificate for app.veeambp.com
Detail: 2a02:4780:b:1321:0:2a26:c84a:8: Invalid response from http://app.veeambp.com/.well-known/acme-challenge/oBqJ9MfU5PRpOgXGtYZ_u53Rh5HYy6Vic_pgfSJv7IA: 404
All simulated renewals failed. The following certificates could not be renewed:
Other questions:
It produced this output: see above
My web server is (include version): Nginx 1.14.0
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): I don't have access to this, I can confirm if needed.
Ed
On that IPv6 address, there's a LightSpeed server from the Hostinger platform reporting (with a "You Are All Set to Go!" default page), whereas on IPv4 your nginx is responding (with a "Welcome to nginx!" default page).
This discrepancy is usually caused by one of the two being incorrect, most likely your IPv6 address.
Oh, yeah, Hostinger and wrong IPv6. We see that so often I have my own template for it. Osiris pointed you in the right direction. Maybe the extra bits below are further help.
Once you get your Certbot v1.16 working installing snap on Ubuntu should be easy. See: Certbot Instructions | Certbot Just follow the instructions carefully and test when you are done with sudo certbot renew --dry-run
You have both an IPv4 A record and an IPv6 AAAA record in your DNS
But, the IPv6 address points to a Hostinger service not your server. Hostinger creates this AAAA record automatically for new setups.
You need to update the AAAA address or remove it if you do not support IPv6.
Any client trying to use IPv6 will connect to that Hostinger service instead of your server.
Let's Encrypt favors IPv6 when an AAAA record is present.
See Hostinger article here: How to manage AAAA records | Hostinger Help Center
And use this site to test connections
https://letsdebug.net
Thanks for the advice, I'm looking at making these changes and will let you know if they work!
Ed
