Upgraded to snap and now have problems
I've been using certbot-auto without problems. I've just upgraded to the snap version and it fails. I've also tried
certbot renew --dry-run --preferred-challenges=dns
certbot renew --apache --dry-run --preferred-challenges=dns
which also fail differently.
My domain is: sipitpro.com
Processing /etc/letsencrypt/renewal/mydomain.com-0001.conf
Plugins selected: Authenticator apache, Installer None
Simulating renewal of an existing certificate for mydomain.com and 4 more domains
http-01 challenge for mydomain.com
http-01 challenge for gui.mydomain.com
http-01 challenge for reports.mydomain.com
http-01 challenge for sp5.mydomain.com
http-01 challenge for www.mydomain.com
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/mydomain.com-0001/fullchain.pem
Processing /etc/letsencrypt/renewal/mydomain.com.conf
Simulating renewal of an existing certificate for *.mydomain.com and mydomain.com
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA. You may need to use an authenticator plugin that can do challenges over DNS.
Failed to renew certificate mydomain.com with error: Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA. You may need to use an authenticator plugin that can do challenges over DNS.
The following simulated renewals succeeded:
/etc/letsencrypt/live/mydomain.com-0001/fullchain.pem (success)
The following simulated renewals failed:
/etc/letsencrypt/live/mydomain.com/fullchain.pem (failure)
apache 2.4
Debian 10 (Buster)
No
certbot 1.11.0
Did you also install the appropriate snap certbot DNS plugin?
Check with certbot plugins
Thanks, doesn't look like it - how do I install?:
certbot plugins
* apache
Description: Apache Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache._internal.entrypoint:ENTRYPOINT
* nginx
Description: Nginx Web Server plugin
Entry point: nginx = certbot_nginx._internal.configurator:NginxConfigurator
* standalone
Description: Spin up a temporary webserver
Entry point: standalone = certbot._internal.plugins.standalone:Authenticator
* webroot
Description: Place files in webroot directory
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Please follow the appropriate guide on https://certbot.eff.org, i.e., in your case click on the wildcard tab above the instructions (next to "default"):
It would be nice if the wildcard tab can be directly linked to with #wildcard for example. This is a know issue, but unfortunately not implemented yet.
Note: you only need the parts related to plugins as you already have the certbot snap installed.
Thanks Osiris, all working now.
Note for future reference by the way: if you use options like --preferred-challenges=dns and --apache with the renew subcommand, it might overwrite stored renewal options for certain certificates which were obtained with different options, as certbot will try to renew any certificate due for renewal if you don't specify one or more certificates with --cert-name.
