Using Snap, Renewal fails
My domain is: txtechnician.com
I ran this command: sudo certbot renew --dry-run
myLog.txt (101.5 KB)
2023-04-17 17:23:25,101:DEBUG:certbot._internal.display.obj:Notifying user:
2023-04-17 17:23:25,101:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2023-04-17 17:23:25,101:ERROR:certbot._internal.renewal:  /etc/letsencrypt/live/txtechnician.com/fullchain.pem (failure)
2023-04-17 17:23:25,101:DEBUG:certbot._internal.display.obj:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2023-04-17 17:23:25,101:DEBUG:certbot._internal.log:Exiting abnormally:
  File "/snap/certbot/2913/bin/certbot", line 8, in <module>
    sys.exit(main())
  File "/snap/certbot/2913/lib/python3.8/site-packages/certbot/main.py", line 19, in main
  File "/snap/certbot/2913/lib/python3.8/site-packages/certbot/_internal/main.py", line 1864, in main
  File "/snap/certbot/2913/lib/python3.8/site-packages/certbot/_internal/main.py", line 1636, in renew
    renewal.handle_renewal_request(config)
  File "/snap/certbot/2913/lib/python3.8/site-packages/certbot/_internal/renewal.py", line 559, in handle_renewal_request
    raise errors.Error(
certbot.errors.Error: 1 renew failure(s), 0 parse failure(s)
2023-04-17 17:23:25,101:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
nginx
nginx/1.18.0 (Ubuntu)
Description: Ubuntu 20.04.6 LTS
Yes
No
certbot 2.5.0
Looks like you managed to get a certificate earlier today? crt.sh | 9174657611 You're trying to do a --dry-run now, but for what reason? Just curious.
Also, please provide the entire letsencrypt.log file. The output currently shown does not provide any actual information about the failure unfortunately.
Hi @txtechnician, and welcome to the LE community forum :slight_smile:
Please show the renewal conf file.
Likely: /etc/letsencrypt/renewal/txtechnician.com.conf
The IPv6 path might be broken:
Addresses: 2600:3c00::f03c:93ff:fe95:c6f
           104.237.135.140
curl -Ii4 txtechnician.com
Server: nginx/1.18.0 (Ubuntu)
Date: Mon, 17 Apr 2023 18:25:21 GMT
Content-Type: text/html
Content-Length: 178
curl -Ii6 txtechnician.com
[edit: IPv6 problem was on my side]
I had a problem with the apt version (I was getting an error associated with python, not the same as I am now). So I removed the apt version and switched to snap.
The previous apt version failed yesterday which is what prompted this change.
That is why after installing and implementing the snap version (and renewing) I wanted to test the dry run of the new install to make sure that wouldn't happen agian.
Was the apt version fully removed?
And...
I think that might be your IPv6 that's broken or perhaps specifically the path between you and the server. My IPv6 works fine and so does the tests I did using letsdebug.
Makes sense, snap is the prefered method by the Certbot developers.
Anyway, still interested in letsencrypt.log
:man_facepalming:
my bad
:stuck_out_tongue:
Are other IPv6 sites also down for you yes? Or is it the path between you and OPs server specifically?
All IPv6 was down for me :frowning:
In case it was lost in the shuffle, I will ask one last time:
version = 2.5.0
archive_dir = /etc/letsencrypt/archive/txtechnician.com
cert = /etc/letsencrypt/live/txtechnician.com/cert.pem
privkey = /etc/letsencrypt/live/txtechnician.com/privkey.pem
chain = /etc/letsencrypt/live/txtechnician.com/chain.pem
fullchain = /etc/letsencrypt/live/txtechnician.com/fullchain.pem
[renewalparams]
account = 682fa4b6352da299741f60cc37ead085
authenticator = nginx
renew_hook = systemctl reload nginx
installer = nginx
key_type = ecdsa
Sorry about the late response.
Sorry about that. See attached.
urn:ietf:params:acme:error:serverInternal
This is usually due to some temporary internal issue with the ACME server, not something you can fix from your side.
My advice would be to try again and see what the error is this time, if any.
lol, thanks it works fine.
If the certbot fails in production in this same way. Does it attempt to retry?
Check the cron [or systemd timer] entry.
They should be set to run (check) twice a day.
Depends what you mean with "retry". A single run of Certbot won't, but as it's recommended to try to renew twice a day and 30 days before expiry, Certbot will have 60 attempts in total.
