[How To] Securing your control panel ISPConfig 3 (interface port 8080) with Let's Encrypt
So you want to access your ISPConfig control panel over https and replace the self signed certificates ?
The “copy/paste” guide may found here :
https://www.howtoforge.com/community/threads/solved-ssl-cert-on-ispconfig-3-master-master-multi-server-setup.71727/
I used the following combination:
  1. Use the tutorial on digital ocean
    https://www.digitalocean.com/community/tutorials/how-to-secure-apache-with-let-s-encrypt-on-ubuntu-14-04
    (I am using ubuntu 14.04 at the moment, I believe this will also work for 16.04)
  2. Follow the tutorial here:
    https://coderwall.com/p/9i-ncg/create-ssl-certificates-for-ispconfig-using-let-s-encrypt
I’ve used it on two ispconfig-installations I have. Works like a charm. I’ll check out the link you have above.
Since version 3.1 of ISPconfig, it has support for Let’s Encrypt built in - so you don’t need to do anything manually to add them.
My post was regarding securing the ispconfig administration website. I have ispconfig3.1, but I haven’t really found the way to do this through the system.
ISPConfig 3.1 users now have the latest guide / tutorial in securing their ISPConfig control panel, other major services and other ISPConfig server in their single or multi server setup:
  1. https://www.howtoforge.com/community/threads/securing-ispconfig-3-control-panel-port-8080-with-lets-encrypt-free-ssl.75554/
  2. https://www.howtoforge.com/tutorial/securing-ispconfig-3-with-a-free-lets-encrypt-ssl-certificate/
Thank you.
