I Wrote here step by step how to install letsencrypt on hostmonster using ssh without root access, I would like to know what is the proccess to renew the cert once it expires, do you repeat the original steps and create a new cert from scratch every time or there is a a way to manually renew the existing cert?
there is no renewal in SSL certs it’s just called that for people to understand
every time you renew the certificate you are actually just creating a new certificate with a new serial number
Andrei
