How long does it take for domain to accept Lets Encrypt?
My domain is:www.fork-lift-training.co.uk
My hosting provider, if applicable, is:Ipage
It takes a few seconds to issue a certificate.
Sometimes ACME clients will have other delays, but that’s outside of Let’s Encrypt’s control.
Why do you ask?
Hi @Whino
checking your domain there is a new wildcard certificate, created today - https://check-your-website.server-daten.de/?q=fork-lift-training.co.uk#ct-logs
Let's Encrypt Authority X3 2019-09-13 2019-12-12 *.fork-lift-training.co.uk, fork-lift-training.co.uk - 2 entries duplicate nr. 1
The certificate looks good, because it has the two domain names main-domain + wildcard.
But the certificate isn't used, there is a Sectigo-certificate with another domain name:
CN=*.bizland.com, OU=COMODO SSL Wildcard,
OU=Domain Control Validated
	26.03.2019
	28.06.2021
expires in 654 days	*.bizland.com, bizland.com - 2 entries
Looks like you have to install the certificate.
Thanks for your quick reply.
Until now I have had a paid for SSL certificate on my website which I purchased through my host Ipage.com. I only recently realised they offered a let’s encrypt SSL free of charge. My site doesn’t have any transactions associated with it to speak of so, with a week to go, I cancelled the paid for SSL several hours ago and added a Let’s encrypt SSL
I’ve also got some websites on Freehostia.com which is where I discovered Lets Encrypt. When I added SSL to those it took just a few minutes but my main site, the one on Ipage, is showing as insecure.
Any help would be much appreciated
Regards
Tony Sellick
Thanks very much for your help. I contacted Ipage and they installed the certificate properly. It’s now working:-)
Kind Regards
Tony
