How long will take to get certificate after domain verified
www.connectatchangi.com
the certificate manager status is
Type Reason Age From Message
Normal Started 42m cert-manager Challenge scheduled for processing
Normal Presented 42m cert-manager Presented challenge using HTTP-01 challenge mechanism
Normal DomainVerified 27m cert-manager Domain "www.connectatchangi.com" verified with "HTTP-01" validation
Welcome to the Let's Encrypt Community, Michael :slightly_smiling_face:
Usually a few seconds with a properly-functioning ACME client. Some inbuilt solutions prolong the time for their own internal management processes though.
it's around 1 hour, not sure. how i can check the progress from lets encrypt side , who to contact
Status:
Presented: false
Processing: false
Reason: Successfully authorized domain
State: valid
Events:
Normal DomainVerified 60m cert-manager Domain "www.connectatchangi.com" verified with "HTTP-01" validation
thanks in advance
From what I see:
https://crt.sh/?q=connectatchangi.com
You had one certificate issued about 34 hours ago:
Not Before: Aug 1 12:18:10 2021 GMT
and another certificate issued about 21 hours ago:
Not Before: Aug 2 01:43:15 2021 GMT
You might have had another certificate issued even more recently. A certificate is available from Let's Encrypt within seconds after verification of domain control, so it's not Let's Encrypt holding up the process.
Thanks Griffin,
these are for low testing env, seems prod one not ready yet.
Please use the staging environment for testing. Thank you.
our production certificate already expired, just got renewed
thanks
