Hello,
I am using paid SSL right now and expiring tomorrow. Will I automatically switch to this SSL if I install Let’s Encrypt?
I use Centos 7 and Apache.
Thank you.
Hello,
Thank you.
Basically yes, so you need to set up certbot or acme.sh according to their instructions.
Your apache config will currently be pointing to a couple of files for your existing certificate and when you have finished setting up certbot etc it will point to your new Let’s Encrypt certificate files. I think you usually need an apache restart to start using the new files.
Thank you for the help.
But I get mod_ssl error during installation. More precisely, mod_ssl cannot be found. How can I solve it?
No package mod_ssl available.
