I am using Leadpages to create a landing page that i want to publish to a custom https url (my own WP site). How do i do that in Let’s Encrypt? - I am novice so simple explanations and diagrams would be much appreciated?
I didn’t understand the hosting arrangements that you’re talking about—do you have an existing WordPress site that you want to add HTTPS to? How is that site hosted (or how is that site going to be hosted)?
1: I have created a squeeze page in Leadpages that generated the above URL
2: Leadpages allow you to Customise that URL by replacing lpages.co with your own web URL, but only for http sites.
3: For https sites like mine they provide a link to Let’s Encrypt, which is why I am here.
4: I believe there is a description of how to do what I want on the Let’s Encrypt Home page, but I do not understand it. And that is the reason I generated post.
Yes, thanks! So, it will still be hosted by Leadpages when you’re done? You don’t have some other hosting provider that is hosting http://longstripecreative.com/?
In this case, do they have somewhere in a control panel where you can upload a certificate for your custom domain? Is their link to Let’s Encrypt something like “Go to Let’s Encrypt, get a certificate, and then upload the certificate here once you have it”?
According to the linked documentation, LeadPages automatically supports SSL for domains CNAMEd to them. (In all likelihood they use Let’s Encrypt for this, but they don’t seem to say so explicitly.)
They also support hosting pages on your main domain when it is hosted elsewhere. So if you use(d) one of the top two methods listed at https://support.leadpages.net/hc/en-us/articles/217777528-Can-I-Use-My-Own-Personal-Domain-for-My-Leadpages- (uploading HTML manually or the Word press connector) and not the above link (which is also listed as a third option on this page), then your main domain must have SSL and LeadPages isn’t involved with that since they don’t host your main domain.
