Hello!
I installed letsencrypt on a vps using digitalocean.com. Everything is very easy to follow and implement for this site. The only problem is I need to exclude one page from https and I can’t seem to do it.
I’ve found and tried several solutions from online forums to exclude one page from being secured by https/ssl. None of them seem to work.
Please don’t direct me to an existing solution as I’ve searched for many hours and tried several “solutions” to no avail. Including on this community forum.
I’ve tried many variations using rewrite in .htaccess and none have worked which leads me to believe that the .htaccess isn’t what I should be modifying. Or I’m simply doing it all wrong.
Your site has a redirect in place, could you post how your current (general) redirect works? The answer is probably modifying thát redirect, nót extra stuff somewhere else.
Hey @Osiris, thank you for your response.
It makes sense for there to be a 301 redirect from HTTP to HTTPS after adding the lets encrypt service. The problem is that I don’t want to secure one page.
The .htaccess is unchanged from the default Wordpress additions and nothing happens when I modify the .htaccess to rewrite the HTTPS to HTTP for one page.
Is there another place, or a better place, to make changes so one page won’t be secured? And what would I enter to keep that redirect from occurring?
Thank you @serverco. I tried your solution but it still didn’t work. I have uncovered some more information for you and @Osiris. I’m very unfamiliar with this part of web administration so please bear with me.
Here’s my .htaccess:
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
What I discovered is a file called 000-default-le-ssl.conf appears to be what is responsible for making the site secure.
What do I need to change to make all requests of and inside of mmsa.org/stem-resource-bank not use https? I feel like the answer is in front of me but I lack the knowledge or direction as to how to correctly change this information. I also can’t find anything on Google that gives a good example to follow — probably because I am not asking the right question.
