Hello, i’m trying to register a root domain with about 5 subdomains. As there are various configurations between services, i’m trying to use the manual installation process with dns TXT record verification.
Redacted: using fish.com as an example
$ sudo certbot certonly --cert-name fish.com -d www.fish.com --manual --preferred-challenges dns
It procuded the following output
You are updating certificate fish.com to include domains: www.fish.com
It previously included domains: fish.com
Did you intend to make this change?
(U)pdate cert/(C)ancel: U
dns-01 challenge for www.fish.com
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you're running certbot in manual mode on a machine that is not
your server, please ensure you're okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: Y
Please deploy a DNS TXT record under the name
_acme-challenge.www.fish.com with the following value:
XXXXXXXXX
Before continuing, verify the record is deployed.
Press Enter to Continue
Failed authorization procedure. www.fish.com (dns-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.www.fish.com
Domain: www.fish.com
Type: connection
Detail: DNS problem: NXDOMAIN looking up TXT for
Digital Ocean has the following entry:
HOWEVER, there is no ANSWER sections:
$ dig -t txt _acme-challenge.www.fish.com
; <<>> DiG 9.8.3-P1 <<>> -t txt _acme-challenge.www.fish.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 46967
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;_acme-challenge.www.fish.com. IN TXT
;; AUTHORITY SECTION:
fish.com. 1800 IN SOA ns1.digitalocean.com. hostmaster.fish.com. 1509646706 10800 3600 604800 1800
;; Query time: 112 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Thu Nov 2 14:29:51 2017
;; MSG SIZE rcvd: 112
I dont think thats a valid TXT record.
What is the proper way to manually generate certs using DNS authentication?
