Hostname/IP does not match certificate’s altnames
Hello,
I use the lets encrypt certificate for my domain (https://www.eyes-on-me.de/). On this website a booking app is installed which also sends notification mails to clients. This mail sending function is not working because of this error:
Error [ERR_TLS_CERT_ALTNAME_INVALID]: Hostname/IP does not match certificate's altnames:
Host: eyes-on-me.de. ist not in the cert's altnames: DNS: kundenservereasy12.de
How can I fix that? Could you please help me with that?
Best Regards
Welcome to the community @Classix
Your cert only has the name eyes-on-me.de in it. You need to add the name www.eyes-on-me.de to it so that both work. If you need more advice please complete the questions on the form you were shown as best you can
Hello @MikeMcQ,
thank you for your quick response. How can I add the missing name www.eyes-on-me.de to the cert?
I will try to answer those questions:
My domain is: https://www.eyes-on-me.de/
I ran this command: A third party app on the website was throwing the error when trying to send notification via email
My web server is (include version): Should be latests apache version (did not figured out where to check)
The operating system my web server runs on is (include version): Linux
My hosting provider, if applicable, is: kundenservereasy12.de
I can login to a root shell on my machine (yes or no, or I don't know): Me not, but I can ask my hosting provider to execute some command
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): latest Joomla version
It sounds like you got your cert from your hosting provider. You need to ask them to make a new cert with both names in it.
It looks like Apache is up to some mischief!
Your Postfix has a certificate for kundenservereasy12.de configured and not for eyes-on-me.de. Are you the sysop for that mailserver? If not, you probably should just configure your "third party app" (what app?) to connect to kundenservereasy12.de instead of eyes-on-me.de.
Thank you all for your help.
I've managed to set the correct certificate for 'eyes-on-me.de' in the mailserver settings.
This has fixed the issue.
