Hello,
I have successfully setup letencrypt certificate for my domain(shopohho.com ), but when I tried accessing it, I’m getting this error from my server
FetchError: request to https://shopohho.com/meta?checkoutId=undefined&domainId=undefined failed, reason: Hostname/IP does not match certificate’s altnames: Host: shopohho.com . is not in the cert’s altnames: DNS:*.elliot.store, DNS:elliot.store
Hi @kensanni
checking your domain there is no error visible - https://check-your-website.server-daten.de/?q=shopohho.com
There is a big certificate with 99 domain names.
Your two names are included.
Both connections use that certificate.
Looks like you have a too old browser cache. Same with your link, there is a working + valid certificate.
Thanks @JuergenAuer
That make sense, It was a caching issue. Is there a better way of handling certificates with multiple domain? Also, is it possible to get all domain on a letencrypt certificate?
It's your decision. Max. 100 domain names are possible.
Some users prefer certificates with two domain names (non-www and www), so they have 50 certificates.
Other create one certificate with both non-www and www -> 50 domains, 100 domain names.
JuergenAuer:
It was a great help ! Thank you very much for sharing this !
system
Closed
March 23, 2020, 11:02am
7
