Help With Let's Encrypt
Hello All
i have this isse Error: Let's Encrypt new auth status 429 hestia panel when i try to install ssl in my panel
any one knows how to fix this issue
regards
That can mean several things and can depend on even more things.
Does it say anything else? What's your domain name?
Error: Let's Encrypt new auth status 429 (thatsdeal.com)
$ podman run --rm -ti certbot/certbot certonly --webroot -w . -d thatsdeal.com --register-unsafely-without-email --agree-tos --verbose
Account registered.
Requesting a certificate for thatsdeal.com
An unexpected error occurred:
Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: thatsdeal.com: see https://letsencrypt.org/docs/rate-limits/
Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: thatsdeal.com: see Rate Limits - Let's Encrypt
Where are those other certificates?
i think i have one ofe them from backup
i was testing a panels
AApanel
hestia panel
CWP
Until i stayed on Hestia panel because of emails working on it
So the error means that you've been abusing the Let's Encrypt services by issuing five identical certs from the production environment within the last week. There is never a good reason to be doing this--if you're testing, there's a testing environment for exactly this purpose. If you have a backup of one of those certs (and its corresponding private key), you can use it. Otherwise, you can wait until a week after the first of those certs was issued.
