Help me to create a certificate
www.towzin.com
./certbot-auto --apache certonly -d towzin.com -d www.towzin.com
/opt/eff.org/certbot/venv/lib/python2.6/site-packages/cryptography/init.py:26: DeprecationWarning: Python 2.6 is no longer supported by the Python core team, please upgrade your Python. A future version of cryptography will drop support for Python 2.6
DeprecationWarning
/opt/eff.org/certbot/venv/lib/python2.6/site-packages/acme/jose/jwa.py:110: DeprecationWarning: signer and verifier have been deprecated. Please use sign and verify instead.
signer = key.signer(self.padding, self.hash)
tls-sni-01 challenge for towzin.com
tls-sni-01 challenge for www.towzin.com
Waiting for verification…
Failed authorization procedure. www.towzin.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout, towzin.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
    Domain: www.towzin.com
    Type: connection
    Detail: Timeout
    Domain: towzin.com
    Type: connection
    Detail: Timeout
    Apache version 2.2.15
    centos v6.9
@faramarz install python 2.7 in your server
@gotham - python 2.6 is not the root cause there
@faramarz - you don’t seem to have port 443 open. The TLS-SNI challenge requires port 443 to be open as that what it connects on .
Andrei
please help me create certificate for my site. www.xtimelesstore.com. Please i need help.
@Roseibeh please create a new topic, as this is unrelated to the topic you replied to. What you do, be sure to fill out the questionnaire no assist us in helping you.
