Certification SSL ,, plz help
My domain is: conatixweb.info
ubuntu@ip-172-31-17-140:~$ sudo certbot --apache
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): conatixweb.info
Requesting a certificate for conatixweb.info
Domain: conatixweb.info
Type: connection
Detail: 54.87.140.224: Fetching http://conatixweb.info/.well-known/acme-challenge/rq0h-gDvm5B-AJl0yQFql5aHQucaJ2dYdjMPi6GuHyk: Timeout d
uring connect (likely firewall problem)
Hint: The Certificate Authority failed to verify the temporary Apache configuration changes made by Certbot. Ensure that the listed domain
s point to this Apache server and that it is accessible from the internet.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run
Certbot with -v for more details.
I think apache , how I know?
Linux/UNIX
Ubuntu (Inferred)
no
no
certbot 1.28.0
I
Hi @alshefaa, and welcome to the LE community forum :slight_smile:
There are multiple problems:
  • Multiple IP addresses; One is RFC 1918:
     Addresses: 54.87.140.224
                172.31.0.0
  • Timeout reaching HTTP on IP 54.87.140.224
    You must have a working HTTP site in order to use HTTP authentication.
     curl -Ii 54.87.140.224
