Help install certificate
Hello. My name is Ciulica Daniel Cristian and i have a domain www.fotofilmaripitesti.ro. I need help to install your free Ssl certificate lets encrypt. Thank you
You’re going to have to be more specific in order for anyone to be able to help you. Have you read any documentation? What parts were unclear to you? What is your hosting environment? What is your server OS? Do you have root shell access, or do you use a control panel?
There are literally dozens of tutorials for almost every configuration imaginable already created. I would recommend starting there, and coming back if you happen to run into issues.
There’s a really big button on the Let’s Encrypt home page called “Getting Started” that takes you here. It’d be, as it says, a good place to start.
