hi i need help for this issue :There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: app.linet-sy.com.
i need set ssl quickly
Hi @ahmad
I cannot generate SSL Certificate
that's wrong. Please read your error message. You have already created 5 certificates - use one of these. And read the link shared in the error message.
@JuergenAuer I can not do that i have not any one on my server
i have to generate a new one
how i can fix that
please
So you've asked Let's Encrypt to issue five identical certificates for you within the past week, they've done so, and then you deleted them. Why did you do that, and why do you think they should keep doing work for you that you're going to throw away?
You can issue another cert in a week from the time the first one was issued. Until then, use the staging server when you're testing the service.
We're going to need more information on what you did and what you want to do.
Please answer this_
The version of my client is (e.g. output of
certbot --versionorcertbot-auto --versionif you're using Certbot):
