Hello team,
Could you please help me figure out my certificate issue problem. Ports 80 and 443 are open, nginx is switched off during certificate request (and when nginx is switched on, I can access http://api.staedl.io so my hosted zone and record set seem to be configured OK)
Details are below.
Thank you!
My domain is: api.staedl.io
I ran this command: sudo ./certbot-auto --standalone -d api.staedl.io certonly
It produced this output: Exiting abnormally:
File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 11, in
sys.exit(main())
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1352, in main
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1227, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 123, in _get_and_save_cert
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py”, line 410, in obtain_and_enroll_certificate
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py”, line 353, in obtain_certificate
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py”, line 389, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py”, line 82, in handle_authorizations
self._respond(aauthzrs, resp, best_effort)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py”, line 161, in _respond
self._poll_challenges(aauthzrs, chall_update, best_effort)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py”, line 232, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
FailedChallenges: Failed authorization procedure. api.staedl.io (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for api.staedl.io
it appears I’ve tried above a few too many times since I’m now getting:
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/
My web server is (include version): nginx/1.12.1
The operating system my web server runs on is (include version): AWS Linux
My hosting provider, if applicable, is: AWS
I can login to a root shell on my machine (yes or no, or I don’t know): YES
