Certificate not generated
My domain is: api.alisuq.me
sudo certbot certonly -a nginx --agree-tos --no-eff-email --staple-ocsp --email emranlateef786@gmail.com -d api.alisuq.me -v
Requesting a certificate for api.alisuq.me
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see Failed Validation Limit - Let's Encrypt
ubunut
Hi @imranrrr, and welcome to the LE community forum :slight_smile:
That limitation will expire within one hour of being triggered.
That said, you should NOT continue to try something that is obviously failing (continuously).
We call that process "Testing".
If you are still in the testing phase, you should use the LE test environment [not the LE production environment].
As for what specific reason your requests fail, we might find more information about that in the logs file:
/var/log/letsencrypt/letsencrypt.log
Also Let's Debug http-01 is showing errors Let's Debug
Best Practice - Keep Port 80 Open
And you were able on 2022-09-17 to get a certificate crt.sh | api.alisuq.me
Testing and debugging are best done using the Staging Environment as the Rate Limits are much higher. Rate Limits are per week (rolling).
