Handshake failure during cert installation, Ubuntu 16.04 running nginx
Hello,
I'm trying to add certificates using certbot to a new, up to date Ubuntu 16.04 server running nginx 1.10.3.
My domain name is theos-test.com.
Here's the command and the output:
theo@ubuntu-512mb-nyc3-01:/etc/nginx/sites-enabled$ sudo certbot --nginx --staging --test-cert -d theos-blog.com -d www.theos-blog.com
tls-sni-01 challenge for theos-blog.com
tls-sni-01 challenge for www.theos-blog.com
Failed authorization procedure. www.theos-blog.com (tls-sni-01): urn:acme:error:tls :: The server experienced a TLS error during domain verification :: remote error: tls: handshake failure, theos-blog.com (tls-sni-01): urn:acme:error:tls :: The server experienced a TLS error during domain verification :: remote error: tls: handshake failure
   Domain: www.theos-blog.com
   Type:   tls
   Detail: remote error: tls: handshake failure
   Domain: theos-blog.com
   Type:   tls
   you have an up-to-date TLS configuration that allows the server to
   communicate with the Certbot client.
I've confirmed that ports 80 and 443 are permitted through the ufw firewall:
sudo ufw status
reveals:
Status: active
To                         Action      From
22                         ALLOW       Anywhere
Nginx Full                 ALLOW       Anywhere
22 (v6)                    ALLOW       Anywhere (v6)
Nginx Full (v6)            ALLOW       Anywhere (v6)
Any assistance is much appreciated.
Figured out the problem as soon as I posted. Wrong domain name! Sorry for wasting your time!
