installed google cloud server and uploaded cpanel on it.
Let ssl give me a license error when i want to install
eror
How can I fix ?
eror
How can I fix ?
hi @sisore
Try reading the error message as I think it’s pretty clear.
The software you are using is licensed.
You can talk to the vendor who makes the software to sort your issue
https://letsencrypt-for-cpanel.com/
Andrei
You can also use AutoSSL with cPanel. AutoSSL is free: https://blog.cpanel.com/announcing-cpanel-whms-official-lets-encrypt-with-autossl-plugin/
Also try acme.sh on GitHub.
The -w is the writable directory exposed to the web, not w the domain added.
Thus the command is:
./acme.sh --issue -d www.WEBSITE.com -w /home/myUsername/public_html -d WEBSITE.com --staging
Check w your hosting where you could see a text file, e.g.
Also open source.
Sets up renewals too.
