Issue with LetsEncrypt
My domain is: myrani.com
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: nonic
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Cpanel
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21.0
When i try to enable LetsEncrypt on WHM after Cpanel installation I am getting this error
API failure: Net::ACME2::x::HTTP::Network: The system failed to send an HTTP “GET” request to “https://acme-v02.api.letsencrypt.org/directory” because of an error: SSL connection failed for acme-v02.api.letsencrypt.org: SSL connect attempt failed error:0A000086:SSL routines::certificate verify failed ...propagated at /usr/local/cpanel/3rdparty/perl/536/cpanel-lib/Net/ACME2/HTTP.pm, line 225
I have tried reinstalling Cpanel and OS twice already.
Please do help
Hello @Lohit, welcome to the Let's Encrypt community. :slightly_smiling_face:
Please share the output of openssl version and curl -v https://acme-v02.api.letsencrypt.org/directory.
Also looks the same error as cPanel AutoSSL Error On WHM
Check you are on the latest version of everything, especially cpanel and all OS updates.
openSSL version : 3.0.2
and
Blockquote
curl -v https://acme-v02.api.letsencrypt.org/directorycurl -v https://acme-v02.api.letsencrypt.org/directory
  • Trying 2606:4700:60:0:f53d:5624:85c7:3a2c:443...
  • Trying 172.65.32.248:443...
  • Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
  • ALPN, offering h2
  • ALPN, offering http/1.1
  • CAfile: /etc/ssl/certs/ca-certificates.crt
  • CApath: /etc/ssl/certs
  • TLSv1.0 (OUT), TLS header, Certificate Status (22):
  • TLSv1.3 (OUT), TLS handshake, Client hello (1):
  • TLSv1.2 (IN), TLS header, Certificate Status (22):
  • TLSv1.3 (IN), TLS handshake, Server hello (2):
  • TLSv1.2 (IN), TLS header, Finished (20):
  • TLSv1.2 (IN), TLS header, Supplemental data (23):
  • TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
  • TLSv1.3 (IN), TLS handshake, Certificate (11):
  • TLSv1.3 (IN), TLS handshake, CERT verify (15):
  • TLSv1.3 (IN), TLS handshake, Finished (20):
  • TLSv1.2 (OUT), TLS header, Finished (20):
  • TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
  • TLSv1.2 (OUT), TLS header, Supplemental data (23):
  • TLSv1.3 (OUT), TLS handshake, Finished (20):
  • SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
  • ALPN, server accepted to use h2
  • Server certificate:
  • subject: CN=acme-v02.api.letsencrypt.org
  • start date: Jan 19 00:13:59 2025 GMT
  • expire date: Apr 19 00:13:58 2025 GMT
  • subjectAltName: host "acme-v02.api.letsencrypt.org" matched cert's "acme-v02.api.letsencrypt.org"
  • issuer: C=US; O=Let's Encrypt; CN=R10
  • SSL certificate verify ok.
  • Using HTTP2, server supports multiplexing
  • Connection state changed (HTTP/2 confirmed)
  • Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
  • Using Stream ID: 1 (easy handle 0x55fdfbbdaeb0)
GET /directorycurl HTTP/2
Host: acme-v02.api.letsencrypt.org
user-agent: curl/7.81.0
accept: /
  • TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
  • old SSL session ID is stale, removing
  • Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
    < HTTP/2 404
    < server: nginx
    < date: Sat, 01 Feb 2025 04:23:20 GMT
    < content-type: text/plain; charset=utf-8
    < content-length: 19
    < x-content-type-options: nosniff
    404 page not found
  • Connection #0 to host acme-v02.api.letsencrypt.org left intact
  • Found bundle for host acme-v02.api.letsencrypt.org: 0x55fdfbbd4b30 [can multiplex]
  • Re-using existing connection! (#0) with host acme-v02.api.letsencrypt.org
  • Using Stream ID: 3 (easy handle 0x55fdfbbdc1b0)
GET /directory HTTP/2
accept: /
accept: /
Blockquote
On latest cpanel version
Ok, best to log a support ticket with Cpanel to ask why their software cannot connect. The issue will usually be that Cpanel is communicating with an outdated CA certificates trust store and they may have a command to refresh that.
